Author Topic: Help with substitute ballast. 50 HPS  (Read 8373 times)
Re: Help with substitute ballast. 50 HPS « Reply #15 on: August 23, 2025, 04:54:28 AM » Author: RRK
Small correction: 350 Ohms for 35W lamp.
As for lamp color - are you sure you really have a rare/non-existent  European spec high voltage 35W HPS, and not S76 52V 0.83A American low voltage HPS?
The later will run with a slight underdrive on 58W choke and will give that regular orange HPS color.
Timlx1
Re: Help with substitute ballast. 50 HPS « Reply #16 on: August 23, 2025, 05:08:49 AM » Author: Timlx1
Oh no not a rare European lamp these 35w lamps are generic Sylvania clear 35w ones from the USA. I picked up half a dozen really cheaply and even with shipping they were worth it. Yes definately 52v .83A off the data sheet.
Tim
Re: Help with substitute ballast. 50 HPS « Reply #17 on: August 23, 2025, 07:14:28 AM » Author: RRK
Well, that makes sense now. Note with 52V lamp you are starting to toast the choke which was made for 105-110V TL lamp. Still probably OK for short time running open air.
