Author Topic: Gases in vacuum incandescent lamps?  (Read 8018 times)
Re: Gases in vacuum incandescent lamps? « Reply #15 on: May 30, 2015, 07:09:24 AM » Author: Medved
All that is when a voltage of 30kV and above was present and had the chance to accelerate higher amounts of electrons (= higher currents at the same time). With the lowering voltage the "efficiency" becomes so low, it is not any hazard anymore. Plus with the lower voltage than the ~30kV limit the energy of the generated photons becomes so low, it can not penetrate anything. So yes, a meter could respond to them when placed just close to the emitting place, but e.g. the regular wooden cabinet already reduces it so, you need long time to detect it...
For the tubes designed to generate the Xray on purpose, you have to use hard metals (tungsten,...) for the anode and make sure they do not warm up during operation (rotating anode,...), to get reasonable output from still reasonable voltage (50..100kV for the medical use)
In the TV's, the warnings and shields are there really to just cover the failures and maybe warmups, when the dangerous voltages (from the perspective of their potential to generate dangerous levels of X-ray) really could be present.
And the plastic covers are there for another reason: The CRT is a big vessel with vacuum inside. So when the glass crack, there is quite high energy "available" to throw heavy glass pieces arround...
Re: Gases in vacuum incandescent lamps? « Reply #16 on: May 30, 2015, 11:02:23 PM » Author: Solanaceae
I've broken CRTs open to examine the electron gun assembly (yeah I know, led poisoning, bad for environment, etc.) but I noticed that the filaments in the electrode guns as well in triode tubes have some white or gray stuff on them. Is it emitter coating just like that used on fluoro lamp electrodes?
Re: Gases in vacuum incandescent lamps? « Reply #17 on: May 31, 2015, 04:42:06 AM » Author: Medved
The filament itself is just coated with an insulation ceramic layer. The emission coating is on the cathode - in amplifier or rectifier tubes that is usually in the form of a nickel tube (either round coated all around in the middle section, for higher current cathodes the tube is flattened, with the emission coating on the flat sides), in CRT's it is a small can (the emission layer is just a dot in the can flat center - to help focus the beam)
hannahs lights
Re: Gases in vacuum incandescent lamps? « Reply #18 on: May 31, 2015, 08:29:36 AM » Author: hannahs lights
I would like to as tolivac what transmitter site do you work at? I'm just curious
