Author Topic: My first experience with a SOX lamp  (Read 8338 times)
CEB1993
Camden
Camdenburns93
Re: My first experience with a SOX lamp « Reply #15 on: February 15, 2018, 04:06:32 PM » Author: CEB1993
Thank you very much, Owen!  That’s a big help  :)
Stop the lamp bans!
Lodge
Re: My first experience with a SOX lamp « Reply #16 on: February 15, 2018, 09:06:04 PM » Author: Lodge
Use the PF cap, Autoleak ballasts with out a PF cap can consume a few amps and that will just translate into heat in the ballast and wiring, and wear on your switch contacts it comes with the cap so you might as well use it.. But it will work with out it, and it won't cost a residential user more to run it unless you have demand billing in your area, in which case it will cost you more to run with out a PF cap..
