Author Topic: Is there a way to install an American ceiling fan in a 240v country?  (Read 21232 times)
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #15 on: November 14, 2020, 03:25:13 PM » Author: Binarix128
Swapping a motor to one that works on your voltage sounds smart, unless it is a super rare fan or you want to operate it with the original motor, running on 110v 50Hz won't make much difference and if it is a rare or collectable fan you won't operate it 24/7.
UChBXesrxSalDTp79uMtfDvA
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #16 on: November 14, 2020, 04:13:11 PM » Author: WorldwideHIDCollectorUSA
Ive been imagining what happens when a 120v light bulb is wired in series with the 120v fan.
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #17 on: November 14, 2020, 04:16:22 PM » Author: HPS_250
Wow, I noticed that you reached 500 posts already! I’ve been here for nearly a year and I’m only at 408!
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #18 on: November 14, 2020, 04:18:19 PM » Author: WorldwideHIDCollectorUSA
I am really one such curious person.
HPS_250
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #19 on: November 14, 2020, 04:19:15 PM » Author: HPS_250
Definitely! There’s nothing wrong with being curious, I was just like that when I first joined this site. :)
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #20 on: November 14, 2020, 04:21:32 PM » Author: WorldwideHIDCollectorUSA
I also like to help LG members from around the world with particular questions.
Binarix128
220V AC 50Hz, NTSC
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #21 on: November 14, 2020, 05:11:20 PM » Author: Binarix128
I'm very curious too. That's why I make many questions about lighting and other stuff and reached the 500 mark in one year. There's nothing wrong with being curious and making questions, after all that site is for getting knowledge rather than showing collections. I came here with very little lighting and English knowledge, now after a year here I'm a little more advanced, I didn't even knew how to difference a MV from a HM.  ;D
If you want to know more about lamps I recommend you to check James's website lamptech.co.uk. It's a wiki with lamps info and an index of factory locations, videos of tv advertisements and more.
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #22 on: November 14, 2020, 06:07:40 PM » Author: Medved
Both will be overvolted. Or at least one of them. The reason is the rather high phase shift in the motor, but nearly none with the lamp.
If tze phase shift is different, the vootages sum up vector as vectors (in a triangle). So the 240V may distribute like 2x150V or so.
Binarix128
220V AC 50Hz, NTSC
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #23 on: November 14, 2020, 06:29:14 PM » Author: Binarix128
Wiring the fan in series with and incandescent bulb of the same power and adding a capacitor to the motor to compensate the phase shifting might work. What about running the fan in series with a lamp ballast of the same power?
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #24 on: November 14, 2020, 07:26:25 PM » Author: WorldwideHIDCollectorUSA
When you mean similar power lamps, do you mean similar line voltage or wattage? From my understanding, power is rated in watts and voltage is the electromotive force. It is true that there are incandescent lamps that can have the same power in watts but have different voltages.
« Last Edit: November 14, 2020, 07:29:18 PM by WorldwideHIDCollectorUSA » Logged
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #25 on: November 14, 2020, 09:43:22 PM » Author: funkybulb
  Lol Woldwide Hidlamp
   In the US we can make A19 E26 bulbs 6 volt all the way to
  300 volts.
   120 volt 100 watt bulb will draw current .83333 of an amp
     12 volt 100 watt bulb is 8.33 amps current draw
    Let sat u have a 60 Volt 60 watt ped signal bulbs
    Yes it runs two in series in there on 120 volt
    But I only have one such lamp.
     60 volt 60 watt bulb draws one amp
     But to power it on 120 volt u can kiss that
    Lamp good bye.  So what i did i fund a lamp
   That draws 1 amp 120 volt. And that  would
  Be GE wattmiser Par38 120 watt bulb.
   Since both lamp draws 1 amp.  I went ahead
  Put 60 watt 60 v and 120 volt together in series
  It lit the 60 watt ped signal bulb at full power
  While 120 volt par 38 120 watt half dim
   This is the formula voltage x Amps= watts
     This is a very important basic electrical
   Formula that u must remember.
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #26 on: November 14, 2020, 11:19:13 PM » Author: Medved
Then still a problem remains:
Stopped fan consumes higher power and mainly at higher currents than running one. So either you make the setup around runningfan and so the lamp gets overloaded during spin up, or around stopped fan and then the fan (andmaybe the bulb as well, due to overcompensation) gets overloaded when running.
A fluorescent ballast has the advantage of its thermal mass, able to cover the 9verload for the spin up, but it by itself means a load varying during lamp startup, now the weak supply causing the ballast to not start properly.
 Anyway even in very optimal case, the setup would need precise balancing to not overload either part, which is nearly impossible (the mechanical load has huge variability there).
So it may "work" on paper, but in reality it would be very unreliable as best.
Better to use a transformer, if you can not swap or rewire the motor (many may be wound using two sections, which are connected in series or parallel for different markets).
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #27 on: November 14, 2020, 11:21:30 PM » Author: WorldwideHIDCollectorUSA
I would be interested in knowing if step down transformers can be installed in the attic where the fan is to be installed.
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #28 on: November 15, 2020, 03:31:42 PM » Author: Ash
A ballast can be used, but maybe instead of connecting it in series with the "entire" motor, connect it only in series with the main winding. The phase shift winding leave connected without the ballast, but change the capacitor value to get the same current at the new voltage
Re: Is there a way to install an American ceiling fan in a 240v country? « Reply #29 on: November 15, 2020, 08:56:44 PM » Author: Medved
It can be a toroidal autotransformer in the fan "base". The fans are heavy so need substantial anchor anyway, which shoul be able to handle the toroidal autotransformer as well.
The motors usually need higher currents for startup (when they tend to loose the magnetic "grip") but then let the current to drop when it is at speed, so the ballast isn't good idea.
