Author Topic: Clear MV lamp color  (Read 4261 times)
bluelights
Clear MV lamp color « on: June 01, 2009, 11:27:29 AM » Author: bluelights
Today I have fired up a tanning lamp which has a clear 125W high-pressure mercury burner in it. From what I saw and read on the net, I always thought that clear MV arcs are blue-green, but nope! It was brilliant cool white in color, maybe a bit blue-white but not green at all!
Maybe it's my eyes? How do you perceive the color of clear mercury bulbs?
« Last Edit: June 01, 2009, 02:18:40 PM by bluelight » Logged
Save the mercury lamp
Re: Clear MV lamp color « Reply #1 on: June 01, 2009, 12:03:51 PM » Author: Roi_hartmann
I have only seen one clear merc with my own eyes. I would call the color green-blue. and ofcourse there were no red color at all.
hotrestrike
Re: Clear MV lamp color « Reply #2 on: June 01, 2009, 03:44:07 PM » Author: hotrestrike
If it's a tanning lamp, you should NOT be looking at it directly! Hopefully you are viewing it behind glass. I had one of these in an old "Sunlamp" fixture - and like all clear mercury lamps, it is a brilliant white, but with a blue-green tinge, which is more noticeable when you either view the lamp from a distance or view its reflection and certainly in photographs.
Also, if you spend enough time under most any light, your eyes will adjust to it so it appears more white. I remember spending several hours in a purely HPS-lit gymnasium...it seemed normal after a while, and then incandescent lamps and daylight looked very strange afterwards.
BTW some of the mercury sunlamp lights are self-ballasted, so they will appear more white due to the blended light from the arc tube & incandescent filament. The latest HID tanning lamps are metal halide - I don't know the halide salts used in these, but they seem to appear "white" like ordinary MH lamps.
bluelights
Re: Clear MV lamp color « Reply #3 on: June 01, 2009, 04:56:42 PM » Author: bluelights
This one is ballasted by heater elements which do not give off any visible light.
And yes I was wearing sunglasses and didn't look at the burner directly.
I pointed it at the wall and when I walked through the house and then looked back into my room, it was almost like being lit with ~6000-7000K fluorescents, with absolutely no green tinge (here I just looked at the reflection on the wall without anything over my eyes).
Re: Clear MV lamp color « Reply #4 on: June 01, 2009, 05:38:28 PM » Author: Medved
What i have an experience, mainly with HR50W/S i sometimes use above my desk ( here ), clear (or not color corrected, as the my one is only diffused) lamps itself are looking blue-white (i think mix of blue with green/yellow is responsible for it), but objects they are illuminating tend to look greenish (wall, desk; the blue is relatively more attenuated, so the yellow/green peak out). Definitely the red is missing: What is normally red, look VERY dark... Special things are office papers, as they do contain some whiteners, what convert UVA to something (blue-green), so they appear unnaturally bright. And other thing is skin - as it normally absorb nearly all blue, the lamp gives it greenish-gray look. And all hematoms, even those normally invisible (assumed as healed), pop up, so the one's overall look is really scary, really like Zombie...
