Author Topic: 100 watt mercury vapor ballast  (Read 13662 times)
RadxD461
100 watt mercury vapor ballast « on: February 13, 2021, 06:28:48 PM » Author: RadxD461
I'm in need of a 100-watt mercury vapor ballast. I'll pay thirty bucks for it.
Bulbman256
Kick the AI scrapers off LG
Bulbman256
Re: 100 watt mercury vapor ballast « Reply #1 on: February 13, 2021, 06:43:27 PM » Author: Bulbman256
I can give you a dead one for 30. :mrg:
Re: 100 watt mercury vapor ballast « Reply #2 on: February 13, 2021, 06:46:52 PM » Author: sox35
Do I have to get with the  :slap: again..?  :mrg:
Bulbman256
Bulbman256
Re: 100 watt mercury vapor ballast « Reply #3 on: February 13, 2021, 08:06:22 PM » Author: Bulbman256
He didn't specify that it had to work. :mrg: :lol:
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: 100 watt mercury vapor ballast « Reply #4 on: February 13, 2021, 08:44:29 PM » Author: Binarix128
If you want to test the MV you can use a resistive load in series. For a 100W MV I'd recommend you a 250W incandescent lamp. If you need a "solid state" ballast you could use normal fluorescent chokes in parallel (normal inductive chokes, not rapid start, nor electronics, nor ones with additional "fancy features") until you reach the desired current.
RadxD461
Re: 100 watt mercury vapor ballast « Reply #5 on: February 13, 2021, 09:46:31 PM » Author: RadxD461
I would really just want a ballast.
Re: 100 watt mercury vapor ballast « Reply #6 on: February 13, 2021, 10:55:08 PM » Author: joseph_125
I would either get a NOS one from eBay, or get a 70w MH ballast and remove the ignitor.
The putting a incandescent lamp in series to ballast a MV really only works when using 240v. The 120v power in North America doesn't have enough voltage for the drop across the incandescent and the MV. Hence why 120v MV ballasts are really small current limited transformers.
« Last Edit: February 13, 2021, 10:56:46 PM by joseph_125 » Logged
Re: 100 watt mercury vapor ballast « Reply #7 on: February 13, 2021, 11:08:41 PM » Author: wide-lite 1000
Here's the closest I could find to your budget : https://www.ebay.com/itm/100-Watt-Mercury-Ballast/265024159131 Since it does have best offer , maybe you could save a bit at least .
Bulbman256
Bulbman256
Re: 100 watt mercury vapor ballast « Reply #8 on: February 13, 2021, 11:14:14 PM » Author: Bulbman256
DO NOT BUY THIS!!!!!!!!!!!!!!!!!!!!!!!!!!!! THE SELLER SENT ME A CHEAP HX BALLAST< HE IS UNTRUSTWORTHY!!!!!!!!!!!1 >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:(
Re: 100 watt mercury vapor ballast « Reply #9 on: February 13, 2021, 11:17:25 PM » Author: wide-lite 1000
Really !? I've bought a bunch of things from this seller with no problems. He's also a member here.
RadxD461
Re: 100 watt mercury vapor ballast « Reply #10 on: February 13, 2021, 11:20:15 PM » Author: RadxD461
you have mistaken.
Binarix128
220V AC 50Hz, NTSC
Re: 100 watt mercury vapor ballast « Reply #11 on: February 13, 2021, 11:24:06 PM » Author: Binarix128
But there actually are SBMVs for the 120V market, you just need the right current drop. Also a 120V 250W bulb has half the resistance of the 240V one, so half the current drop, but the operation voltage is the half so they compensate, and if I'm not wrong, the tube tube should receive the same current with a 120v and 240V incandescent bulb, operating at their respective voltage.
Bulbman256
Bulbman256
Re: 100 watt mercury vapor ballast « Reply #12 on: February 13, 2021, 11:25:44 PM » Author: Bulbman256
Oh wait........... :-[ :-[ :-[ :-[ :-[ This is a similar seller to the not trusty one, your fine, my mistake. :-[ :-[ :-[ :-[ :-[
RadxD461
Re: 100 watt mercury vapor ballast « Reply #13 on: February 13, 2021, 11:26:08 PM » Author: RadxD461
would this work for a permanent set up?
Re: 100 watt mercury vapor ballast « Reply #14 on: February 13, 2021, 11:29:01 PM » Author: joseph_125
While you can get the correct current the voltage isn't high enough for conventional MV. Remember than the 120v SBMV lamps have special arctubes that have a lower arc voltage and hence won't cycle on 120v and they have preheating filaments to allow for starting that the 240v SBMVs lack.
It probably would as long as you have it wired up correctly and are running on 240v power. That's basically how 240v SBMV lamps are laid out internally. A MV arc tube connected in series with a incandescent filament as a ballast.
« Last Edit: February 14, 2021, 12:00:45 AM by joseph_125 » Logged
