Author Topic: High Pressure sodium Ignitor  (Read 3900 times)
form109
High Pressure sodium Ignitor « on: June 26, 2009, 08:30:51 PM » Author: form109
does anyone know where i can Find a Two or three Wire HPS Ignitor...
will a Two Wire Ignitor Work with a S-62 (70 Watt) HPS Ballast Designed to be used with a three Wire Ignitor?
and whats the diffrence between a Two and Three wire Ignitor?
Re: High Pressure sodium Ignitor « Reply #1 on: June 28, 2009, 03:23:06 PM » Author: Medved
It is not really matter of the ballast, but of the ignitor, if it is able to work with the lamp.
What does matter are:
- the amlitude of the ignition voltage pulse on the lamp. If the two-wire is capable to make high enough voltage pulse (EU 70W HPS is happy with 1.5..2.5kV, so i guess the US 55V type would need something in the range 800V..1.5kV), on parallel ignitor this would be written
- The ballast OCV (to trigger correctly the ignitor)
Both (or the S62 compatibility statement) you should be able to find in the ignitor's datasheet.
