Author Topic: Where to get class H ballast varnish?  (Read 2191 times)
Where to get class H ballast varnish? « on: October 03, 2021, 10:12:00 PM » Author: HomeBrewLamps
I would like to get coil varnish for some HID ballasts in the future for some of the ballasts I have laying about in need of restoration. But not sure where to look for it.
Re: Where to get class H ballast varnish? « Reply #1 on: October 05, 2021, 08:53:49 PM » Author: HomeBrewLamps
Anyone? I need high a source of high heat varnish or an alternative.
Gearjammer
Re: Where to get class H ballast varnish? « Reply #2 on: October 05, 2021, 09:14:45 PM » Author: Gearjammer
I was hoping that someone would answer this as I need some myself.
I know that MG Chemicals makes it I just have to figure out who sells it.
Re: Where to get class H ballast varnish? « Reply #3 on: October 05, 2021, 09:43:44 PM » Author: wide-lite 1000
Ask joseph_125 . He just revarnished one recently . Someone else did too , I just can't remember who .
Lightingguy1994
Re: Where to get class H ballast varnish? « Reply #4 on: October 05, 2021, 10:23:28 PM » Author: Lightingguy1994
Following.
Re: Where to get class H ballast varnish? « Reply #5 on: October 05, 2021, 10:31:13 PM » Author: joseph_125
MG Chemicals 4228 is the red varnish I use. It looks like this when applied on a ballast. You can also use MG Chemicals 4226 if a clear/transparent product is desired. Both are rated to Class H and should be good for everything except 1000w ballasts, which use Class N varnish.
I get mine from a local electronics shop called Sayal Electronics but here's some links to you folks in the US that might need to order it. A 55ml jar is enough for around 2-3 ballasts.
Digi-Key:
4228
4226
Amazon US:
4228
4226
eBay US:
4228
4226
