Author Topic: HD has Advance F54T5HO on clearance for $10/ea  (Read 4508 times)
589
Tha SOX MADMANNN
HD has Advance F54T5HO on clearance for $10/ea « on: November 05, 2021, 01:17:41 PM » Author: 589
Not sure about nationally, but both local HDs near me had these on clearance and I got the last two for use with F40T12s later.
https://www.homedepot.com/p/Centium-49-54-Watt-120-277-Volt-1-or-2-Lamp-T5HO-Programmed-Start-Electronic-Fluorescent-Replacement-Ballast-502211/202977281
I also found an interesting easter egg in the description that was certainly an error, still is fun though.
:lps:
Bulbman256
Kick the AI scrapers off LG
Bulbman256
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #1 on: November 07, 2021, 09:44:27 PM » Author: Bulbman256
Well it's still 37 bones online in the show me state, so no sale here. :-\ If i needed it and it was on sale then i would grab it, but otherwise it says on the shelf for me.
One question i want to ask is why did you reballast the F40T12 light with these, the one i have works pretty well. :wndr:
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #2 on: November 08, 2021, 12:01:56 AM » Author: xmaslightguy
@Bulbman256:
Its just another option if you want an electronic ballast that'll drive F40's at around full power.
Bulbman256
Bulbman256
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #3 on: November 08, 2021, 12:09:10 AM » Author: Bulbman256
Gotcha, didn't know you could do that. :bulbman:
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #4 on: November 08, 2021, 12:31:09 AM » Author: joseph_125
I wonder if T12s last longer when switched frequently on one of those compared to a standard electronic T12 ballast. I know some T12 electronic ballasts don't really rapid start the lamps and instant start them like T8s instead.
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #5 on: November 08, 2021, 09:50:31 PM » Author: xmaslightguy
@joseph_125:
I would think they should last longer with these than with one of those that basically instant-starts.
Some of the GE T12 elecrtonic RS ballasts do actually start in a real rapid-start fashion.  I think those too should do decent for lamp life...
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #6 on: November 08, 2021, 09:53:58 PM » Author: xmaslightguy
Also I saw a 4xF54T5 ballast on clearance at Home Depot for $11
fluorescent lover 40
Re: HD has Advance F54T5HO on clearance for $10/ea « Reply #7 on: November 08, 2021, 10:51:00 PM » Author: fluorescent lover 40
Was there today. Also saw the F54T5 ballasts on clearance, $13 if I recall correctly.
