Author Topic: Mogul base adapter not working?  (Read 1606 times)
RadiantMV
Mogul base adapter not working? « on: December 03, 2021, 06:32:17 PM » Author: RadiantMV
I have been trying to use a mogul base adapter to light a 450w 120v SBMV on a normal socket and no matter what i do the bulb still won’t light. Am I doing something wrong or is the adapter just garbage?
Re: Mogul base adapter not working? « Reply #1 on: December 03, 2021, 07:05:17 PM » Author: Rommie
Could be anything really, is it a reasonably good quality adaptor or is it cheap crap..? I assume that normal lamps work in the socket, so it has power, right..? Is the lamp known to work..?
Having said that, 450W is a lot for a normal lampholder, but if it and adaptor both check out, it has to be the lamp  :wndr:
Try and get a normal mogul socket and wire it to a plug that you can just plug into a wall socket and see if that works.
RadiantMV
Re: Mogul base adapter not working? « Reply #2 on: December 04, 2021, 03:26:37 PM » Author: RadiantMV
Got it to work with a mogul socket on a cord. Thanks for the help!
