Author Topic: How many fixtures do you have now??  (Read 9082 times)
NiMo
How many fixtures do you have now?? « on: October 18, 2009, 08:40:08 PM » Author: NiMo
This is an update on the "How many Fixtures do you own" thread because we know that most collections change over time.  Mine has nearly tripled since I last posted on this subject
GE M-1000 (1000 watt HPS)
GE M-1000 (1000 watt MV)
GE M-400A1 FCO (250 watt HPS)
GE M-400 Split Door (250 watt HPS)
GE M-400R2 (250 watt HPS)
GE M-400 Silver (400 watt MV)
GE M-400 Grey (400 watt MV/MH)
GE M250A2 (150 watt HPS)
GE M250R2 (100 watt HPS)
Pemco (400 watt MV)
ITT/AE Model 25 (250 watt HPS)
AE Model 125 (400 watt HPS)
ITT/AE Model 13 (175 watt MV)
AE Model 113 (150 watt HPS)
Crouse-Hinds OV-15 (250 watt HPS)
Westinghouse 4th generation OV-25 (400 watt MV)
Westinghouse 3rd generation OV-25 (400 watt MV)
Westinghouse 2nd generation OV-25 (400 watt MV)
Westinghouse 1st generation OV-25 (400 watt MV)
Westinghouse OV-15 (175 watt MV)
Crouse-Hinds OVZ (150 watt HPS)
Crouse-Hinds OVM (250 watt HPS)
Widelite High Bay (250 watt HPS)
Appleton High Bay (250 watt HPS)
Low Bay fixture {Unknown manufacturer}(250 watt MH/MV)
Converted 4 foot shoplight into F48 VHO fixture
Sylvania Ballast-in-Arm NEMA (400 watt MV and 250 watt HPS)
GE Type 201SA (175 watt MV)
Eagle Durasig 12" incandescent traffic signal
Eagle Alusig pedestrian signal
Crouse-Hinds "Breadbox" 8" traffic signal
Lumec Post Top (150 watt HPS)
On the Sylvania luminaire, I saved the other ballast door from the other Sylvania luminaire and installed a 250 watt HPS ballast and can now run either merc or HPS on the same luminaire.
« Last Edit: July 11, 2010, 02:23:09 PM by NiMo » Logged
Group Replacement, Baby
KEDER
Re: How many fixtures do you have now?? « Reply #1 on: October 18, 2009, 08:48:57 PM » Author: KEDER
Just 3.
1) First one i got was m400 r2. 400w HPS
2) then i found my m250r2 on the gound, got a new housing for it and made it as good as new again. 250w HPS
3) then i got my 115 from darren, 150w HpS, but atm i put the 175w mv ballast in it and mounted it up on the deck. better than the former 250w hps.
to sum things up, ill list the fixtures without the descriptions:
1. GE M400 r2 400w HPS
2. GE M250 r2 250w HPS
3. AE 115 150w HPS.
that is my latest.
slz
Re: How many fixtures do you have now?? « Reply #2 on: November 01, 2009, 11:02:40 PM » Author: slz
Back in the early 90's I used to rebuild streetlights as a side business. I rebuilt almost 200 of them. I currently have 15 modern fixtures along with some older incandescent fixtures that I rescued during the conversion here. Pics to come....
chapman84
Re: How many fixtures do you have now?? « Reply #3 on: December 04, 2009, 10:36:41 AM » Author: chapman84
I have 7 now,
American Electric 125 Series (400 watt mercury)
Cooper Lighting OVX (400 watt mercury)
Cooper Lighting OVZ (250 watt HPS)
Cooper Lighting OVZ (175 watt mercury)
Westinghouse OV-15 (250 watt mercury)
Westinghouse OV-25 Remote Ballast (400 watt mercury)
Designer's Edge yard light (100 watt mercury)
gailgrove
MVs at Dusk
Re: How many fixtures do you have now?? « Reply #4 on: December 25, 2009, 02:28:36 PM » Author: gailgrove
I have 22
2 Crouse-Hinds OV15s
1 Westinghouse OV25
4 GE M250R2s
1 Cooper OVX
2 Cooper OVZs
1 PowerLite R37
3 PowerLite R47s
1 Powerlite R7
2 PowerLite B2255s
1 AEL 115
2 AEL 125s
1 T&B model 13
1 T&B model 25
2 Power-Lite Twist-Packs
1 GE post top
1 Sports lighter
And lots of other lamps, ballasts and stuff.
**Updated Dec. 17th, 2010**
« Last Edit: December 17, 2010, 09:16:56 PM by gailgrove » Logged
Say no to Induction & LED, HID forever!
lite_lover
Darren
GoL darren.harward
Re: How many fixtures do you have now?? « Reply #5 on: December 25, 2009, 04:16:56 PM » Author: lite_lover
Great collections and selections,my list of fixtures can be seen in this topic .
The brighter the better.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: How many fixtures do you have now?? « Reply #6 on: December 25, 2009, 08:43:00 PM » Author: Foxtronix
I don't have the possibility to get a lot of streetlights, but I gave an effort to have at least one. One, but not the least, a Sylvania GTE R37.   ;D
tmcdllr
Re: How many fixtures do you have now?? « Reply #7 on: December 26, 2009, 06:30:55 AM » Author: tmcdllr
Mine are all compact floodlights....
(2) Heath-Zenith SL-5675-WH, 100 watt mercury vapor white
(1) Contractorlighting.com Brand 08-SF-100MH-MT, 100 watt pulse start metal halide bronze
(1) Regent 'SFL' type, (originally 100 watt mercury vapor) converted to 100 watt high pressure sodium bronze
(1) Hubbell Microliter MIC-0070H-358, 70 watt pulse start metal halide bronze, I actually had two of these but gutted the other one for the ballast
I also have....
(1) 175 watt Plusrite clear MV bulb
(1) 175 watt Plusrite coated MV bulb
(1) 160 watt Plusrite coated SBMV bulb
(1) 160 watt no name brand clear SBMV bulb
(1) 100 watt Grandlite clear MV bulb
(1) 70 watt Philips MH bulb
Plus each of the fixtures above all have clear bulbs except one of the MV floods has a coated Sylvania 100 watt MV bulb.
Re: How many fixtures do you have now?? « Reply #8 on: December 28, 2009, 12:14:04 AM » Author: joseph_125
Mine are mostly wallpacks and yardlights but I have two streetlights in my collection:
175w MV Health Zenith yardlight with 12" refractor
175w MV Health Zenith yardlight with 10" refractor
100w MV Health Zenith mini bucketlight
35w HPS Designers Edge tallpack
70w HPS Designers Edge tallpack (I have two of them)
50w MH Gardco recessed canopy light
250w MV/MH Sylvania GTE/Powerlite R47 cobrahead (formerly 250w HPS)
250w MV/MH Sylvania GTE/Powerlite B2255 cobrahead (formerly 250w HPS)
I also have lots of various fluorescent fixtures and some loose HID ballasts too.
UPDATED 05-17-10
« Last Edit: May 18, 2010, 12:23:45 AM by joseph_125 » Logged
streetlight98
Mike McCann
Re: How many fixtures do you have now?? « Reply #9 on: May 17, 2010, 05:53:56 PM » Author: streetlight98
Six,
M-400A (400MV)
OV25 Remote
Utilitech wall mount (70MH)
Regent Florescent (13CFL)
Regent HPS (70HPS)
China light (175MV)
