Author Topic: [Found] Wanted: Tridonic or Atco 175w MV Ballast  (Read 4401 times)
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
[Found] Wanted: Tridonic or Atco 175w MV Ballast « on: March 30, 2022, 07:25:03 PM » Author: 108CAM
I'm currently trying to find either a Tridonic or Atco 175w MV ballast to run my BT29 shaped 175w MV bulb on.
A used ballast would be ideal because a new one is too expensive.
« Last Edit: May 27, 2022, 02:00:52 AM by 108CAM » Logged
1925-2002
Bring back the AJF Zodiacs!
UChBXesrxSalDTp79uMtfDvA
Re: Wanted: Tridonic or Atco 175w MV Ballast « Reply #1 on: March 30, 2022, 10:35:25 PM » Author: WorldwideHIDCollectorUSA
Here is a Tridonic/Atco ballast that will run your North American market 175w H39 mercury vapor lamp perfectly:
https://www.ebay.com.au/itm/264241467402
Note that the “130v” on the listing does not represent the mains input voltage since this is a 220v-240v 50hz ballast, but the 130v refers to the lamp’s arc voltage drop. However, the ballast is priced at a little over $200 AUD.
108CAM
Re: Wanted: Tridonic or Atco 175w MV Ballast « Reply #2 on: May 27, 2022, 02:00:19 AM » Author: 108CAM
Update: I have now acquired 2 Atco OMB175 ballasts.
1925-2002
