Author Topic: Wanted: 90 or 180W SOX Lamp  (Read 5648 times)
Econolite03
Matthew E.
Wanted: 90 or 180W SOX Lamp « on: May 07, 2022, 01:46:20 PM » Author: Econolite03
Hi there,
I’m looking for 90 or 180W SOX lamps.
The reason being is this will determine what I get next for the collection, simply because I don’t want to invest in a LPS fixture in those wattages but then have no bulb(s) for it, making it useless. If I could find a 90W lamp then I’d get a 90W fixture for it, if that makes sense. Any web finds, trades, or advice would be greatly appreciated.
Thanks.
All Hail the GE M-400
UChBXesrxSalDTp79uMtfDvA
Re: Wanted: 90 or 180W SOX Lamp « Reply #1 on: May 07, 2022, 01:47:30 PM » Author: WorldwideHIDCollectorUSA
Would you also be interested in any 66w, 91w, and 131w SOX-E lamps too?
Econolite03
Matthew E.
Re: Wanted: 90 or 180W SOX Lamp « Reply #2 on: May 07, 2022, 01:49:00 PM » Author: Econolite03
*edit* If they could run on a 90 or 180W ballast, I’d consider it.
« Last Edit: May 07, 2022, 01:51:21 PM by Econolite03 » Logged
Re: Wanted: 90 or 180W SOX Lamp « Reply #3 on: May 07, 2022, 05:17:45 PM » Author: wide-lite 1000
https://www.ebay.com/itm/294923088617  This would be worth a message to seller as it isn't clear if you'd be getting 1 or 2 for that price !! The item description says "2 each" which leads me to believe they have 2 lots of 2 !!  :poof:
 Either way , the price is worth it for just one !!!!  :lps:
Re: Wanted: 90 or 180W SOX Lamp « Reply #4 on: May 07, 2022, 05:22:43 PM » Author: joseph_125
Yeah, good price for them. Most 180w fixtures should run the 135w lamps too but I guess it'll look a bit strange with the light no going all the way to the end of the reflector.
Re: Wanted: 90 or 180W SOX Lamp « Reply #5 on: May 07, 2022, 05:25:16 PM » Author: wide-lite 1000
Been there , did that : https://www.lighting-gallery.net/gallery/displayimage.php?album=5274&pos=19&pid=158964
Re: Wanted: 90 or 180W SOX Lamp « Reply #6 on: May 07, 2022, 05:48:42 PM » Author: Rommie
How did I miss that one..? Never did understand the poster of the first comment on that, though  :-\
Re: Wanted: 90 or 180W SOX Lamp « Reply #7 on: May 07, 2022, 07:06:30 PM » Author: WorldwideHIDCollectorUSA
The 66w SOX-E lamps are intended as an energy saver version for 90w SOX low pressure sodium lamps while 131w SOX-E low pressure sodium lamps are intended as an energy saver version for 180w SOX low pressure sodium lamps.
Re: Wanted: 90 or 180W SOX Lamp « Reply #8 on: May 07, 2022, 07:09:49 PM » Author: Rommie
Indeed. Savings can be made with normal SOX ballasts, but they perform a lot more efficiently with the correct SOX-E ballasts. Sadly, those are hard to find these days, they were never all that common in the UK to start with, I believe mainland Europe made greater use of them.
Re: Wanted: 90 or 180W SOX Lamp « Reply #9 on: May 07, 2022, 07:11:05 PM » Author: wide-lite 1000
Correct . I think she was referring to the 1st comment of the photo I linked .
Econolite03
Matthew E.
Re: Wanted: 90 or 180W SOX Lamp « Reply #10 on: May 09, 2022, 06:16:06 PM » Author: Econolite03
I don’t mind the SOX-E lamps, if I found one for a fair price I’d probably get it. I don’t want to spoil it, but I plan on acquiring a 180W SOX fixture in the coming month.
