Author Topic: Rapid Start Fluorescent Lights  (Read 5215 times)
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Rapid Start Fluorescent Lights « on: May 11, 2022, 03:21:08 AM » Author: 108CAM
In the US & Canada when rapid start fluorescent lights became popular and preheat lights fell out of favour, some countries like Australia didn't follow suit and kept producing preheat fixtures instead of switching to the newer rapid start technology.
I can't find any information as to why Australia continued to produce preheat lights instead of the newer rapid start lights that were popular elsewhere.
Anyone know why us Aussies stuck with preheat?
Fun Fact:
Many Australian lighting collectors (including me) are happy that preheat lights and ballasts are inexpensive and very easy to find due to not transitioning over to rapid start like the US & Canada.
1925-2002
Bring back the AJF Zodiacs!
Re: Rapid Start Fluorescent Lights « Reply #1 on: May 11, 2022, 04:06:02 AM » Author: funkybulb
  The main differences that between the US and Austraila
Is the Mains voltage in the USA residental lighting and light
Commeral lighting is 120 volt.  While Austraila being on 240 volt.
  Well in order for Fluorescent to work on preheat u need twice the Arc voltage of a fluorescent lamps.  While we can preheat 4w to 8w
 T5 , 10-18 watt in T8s and14 to 25 watts in T12.  As most of these
  a
  Here in the US longer tubes need tte ago have a spontep up auto transformer with just enough current to run and preheat the lamps
Around 210 ocv.  It did not take long to take auto transformer ballast
 To wrap 3 low voltage cathode winding to the preheat ballast componets. The cathode heating lowers the Striking voltage running the lamp 2 in series F40T12 lamps.  Only different is these lamp are constantly heated.  And uses little more energy than normal T12 40watt preheattuned.
Places that have 240 volt.  All u need is a simple choke as 240 volt
Will strike up  30 to 100 watt fluorescent tubes with ease with out stepping up the voltage.  And cathode heating done by preheating the cathode and lamp ignites.  Some ballast will allow u to series
The lower wattage tubes in switch start.  While US can only series
Few hand full of tubes on a choke ballast in manual switch starting
 Such 2 x 14 watt T12 and 2 x 4 watts T5.
   I do know Austraila and UK do have what u call Quick start fluorescent.  It basically heating transformer added in on top of
 Preheat choke.  With lack of a starter.  Basically that how American
Rapid start works.
108CAM
Re: Rapid Start Fluorescent Lights « Reply #2 on: May 11, 2022, 04:09:10 AM » Author: 108CAM
Thanks for the information. I had a feeling it was something to do with the difference in mains voltage
1925-2002
Re: Rapid Start Fluorescent Lights « Reply #3 on: May 11, 2022, 07:06:14 AM » Author: dor123
This is also true to the rest part of the western world. As in Europe the voltage is 230V and in the UK is 240V, they can uses series choke also in high wattage lamps, so preheat is the simplest system for starting fluorescent lamps.
Re: Rapid Start Fluorescent Lights « Reply #4 on: May 11, 2022, 10:47:23 AM » Author: Rommie
Actually the specified voltages in the UK and the rest of Europe are only nominal. Historically, Europe was 220V and the UK was 240V, then it was decided to "harmonise" them to 230V throughout.
However (with one or two exceptions) nothing was actually done, it was purely a paper exercise achieved by varying the tolerances. Here are a few articles from the web on the subject:
https://www.ampworks.co.uk/myth-busters/mains-voltages-in-the-uk-and-the-eu-and-what-it-means-for-guitar-amps/
https://www.leadsdirect.co.uk/knowledge-base/what-is-the-difference-between-uk-voltage-and-european-voltage/
https://www.ecopowersupplies.com/uk-electricity-voltages
UChBXesrxSalDTp79uMtfDvA
Re: Rapid Start Fluorescent Lights « Reply #5 on: May 15, 2022, 10:23:23 PM » Author: WorldwideHIDCollectorUSA
When doing research on fluorescent lighting in Japan, I found out that even when rapid start fluorescent ballasts came to Japan, preheat ballasts including autotransformer ballasts still remained quite popular. You can still easily source both "preheat" 4 foot tubes and "rapid start" 4 foot tubes pretty easily on Japanese websites even in 2022.
bulb_tester2009
Re: Rapid Start Fluorescent Lights « Reply #6 on: May 30, 2022, 11:01:27 PM » Author: bulb_tester2009
Regarding the RS ballast, I had a friend who found an RS ballast in a nearly scrapped fixture when collecting fluorescent lamp fixtures, indicating that it exists at different voltages
:hps: Poor quality lamps in my collection are prohibited. Most of them have been used for my destructive experiments and ballast tests.
Re: Rapid Start Fluorescent Lights « Reply #7 on: May 31, 2022, 05:39:06 AM » Author: dor123
I think that the rapid-start ballast shorten the lamp life, since as it apply voltage and current and heat the cathodes simultaneously, the discharge strikes before the cathodes has been fully warmed (The dim glow exhibited for several seconds before reaching full brightness in rapid-start ballasts) result in cold cathodes mode for several sec. This mode can cause rapid sputtering, as I've seen in the 54W T5 HO fixture in my kitchen of the low floor of my hostel (Despite different technologies, magnetic vs electronic ballasts, the starting process of both ballasts is the same)
Re: Rapid Start Fluorescent Lights « Reply #8 on: May 31, 2022, 08:37:10 AM » Author: funkybulb
No dor that not true about rapid start shorten lamp life.  I had pair of westingouse lamps in the garage as a kid it lasted nearly 25 years
 It lasted until it can no longer strike up. It had 4 orange glow like
 A stuck starter.   When turn om a rapid start fixtue both cathode and ballast ocv is predent at same time.  So it relys on cathode heating for it to even strike two lamps right at 210 volt OCV
  T12s  is rated for 24,000 hours on rapid start.  Other wise  12,000
 Hours on preheat.  Each time lamp blinks on preheat it sputtees off
 Some emission materals.  What do kills tubes in a hurry on  rapid start is bad socket connections  or a bad cathode transformer.   It will Sputter and blacken new lamp within hours of running. Plus there no way for lamp to strike until cathode get heated and warmed
 Up.  As soon as cathode heats up it ionize the gas inside and ramps
With in second or two. So there no cold cathodes from the start.
If u want longest tube life and even longer tube life dor?  U manually
Preheat the tube with normally open switch.  There been desk lamps
Found with 1940s tubes here in the US. So that tells u somthing about manual preheating.
Re: Rapid Start Fluorescent Lights « Reply #9 on: May 31, 2022, 01:18:55 PM » Author: Roi_hartmann
I agree, but 24 years in a garage, 80 years in a desk lamp doesn't really tell anything about the amount of hours that a lamp has done.
Re: Rapid Start Fluorescent Lights « Reply #10 on: May 31, 2022, 03:05:12 PM » Author: funkybulb
Ok 24 years on that westinghouse pair tubes I had on rapid start
  It being in resdential garage.  The light runs any where from 5 mins
 To 24 hours of running.  And me being a kid with all that short switching the tubes watching them start up is hard on the tubes
 Try that on switch start or instant start it would been dead long
 Time ago with way more sputtering and shorter life like a kid playing
 With light switch.  And it took my child hood abuse,  have dog in the garage leaving lights on half the time.  And all this short switching
5 10 mins then back off this can be few times a day.  Now this kinda
What saying just so random hours of use and excessive switching cycles than normal.
  Now the old desk lamps just a ovservation on manual preheat
Lasting longest.  It because u dont find 20,  F30 and F40s working
Today and tubes in the 40s never lasted very long. So low use desk lamp from that era and be found.  And manual preheating is least sputtering on the tubes by observation.
108CAM
Re: Rapid Start Fluorescent Lights « Reply #11 on: May 31, 2022, 07:37:55 PM » Author: 108CAM
Since I discovered I had a USA market F20T12 Philips rapid start tube in my collection, I now know why it wasn't fully working in any of my preheaters. It lit up but was very dim and you could actually see the mercury struggling to vaporise
1925-2002
Re: Rapid Start Fluorescent Lights « Reply #12 on: June 01, 2022, 01:08:52 AM » Author: joseph_125
IIRC I believe consumer attitudes in the US and Canada also preferred the soft starting of rapid start as opposed to the flashing that preheat lamps had. The reason why I think this is because the rapid start technology was later adapted to run lamps originally designed for preheat operation. These are lamps with a lower arc voltage that would have only required a choke ballasts on a preheat circuit. Even the 4w to 8w T5 lamps had a rapid start ballast available for them.
The other thing is that 240v and 277v F40T12 ballasts are usually rapid start too instead of the simpler preheat choke. It's common in larger buildings to wire the fluorescent lighting circuits to higher voltages. In Canada we had fluorescent ballasts in 347v and 600v too.
Re: Rapid Start Fluorescent Lights « Reply #13 on: June 01, 2022, 06:20:23 AM » Author: Rommie
Here, all lighting runs from 240V single phase. Even if 3-phase comes into the building (commercial/industrial only, almost never domestic, unless it's a very large property), lighting circuits are just taken off one phase, distributed across all three over the building to equalise load.
