| After knowing that high pressure sodium ignitors and pulse start metal halide ignitors like semiparallel ignitors and superimposed ignitors generate high voltage pulses ranging from 2,500v to 5,000v, is their voltage high enough to be considered “lethal”?
| Yes. This is why you should never replace lamps with the power on.
| It is not that much the 2kV from the ignitor itself, but the 200+V from the ballast that will jolt you. The ignitor HV pulse may breakdown the air when you are "just not touching it" (2kV may jump across 1mm, when some sharp corner gets involved), so form a conductive path through the air for that 230V to zap you.
It's current more than voltage which will kill you. 1000V DC from a Megger insulation resistance tester at 1mA will give you a jolt, but it won't kill you. Touching even a 120V live wire might, though. In short, don't mess with electricity. https://www.scienceabc.com/humans/how-many-volts-amps-kill-you-human.htmlhttps://portablepowerguides.com/can-voltage-kill-you/
RCM442
| Remember, it's not the volts or the amps that kill you! It's the wall you get thrown into when you touch it! :'-)
LEDs need to stop taking over everything Administrator Need help with something on the site? Let me know!
108CAM
| Some safety precautions you can take include: 1. Ensure the fixture is properly grounded/earthed so that any electrical leakage is discharged safely 2. Check the wires for any damage to the insulation and if needed, replace with wire of the same rating 3. Inspect the ignitor for any signs of damage 4. Keeping a safe distance away from the fixture during testing
Rest in Peace Electronic Lamp Manufacturers of Australia 1925-2002
Bring back the AJF Zodiacs!
Total incidents since joining LG: 18 Lamps accidently broken or smashed: 15 Ballast explosions/burnouts: 3
Michael
| And one advise from me, don’t ever put the leads of multimeters or other voltage detectors on the lamp wire between ignitor and lamp socket when it’s on! I had one which broke voltage detector after one guy tried to measure on a HPS lamp socket while it was still energized.
