Author Topic: GE Helical Generations  (Read 6757 times)
N3210
lightbulb
UCo_R9kHfa7voRrydT2NJYnw tomloveslighting
GE Helical Generations « on: May 19, 2022, 10:54:47 PM » Author: N3210
I discovered I had 2 generations of GE Helical. I did some google searching and I discovered this:
Correct me if anything is wrong.
1st Generation: Big (Credit to lite_lover)
2nd Generation: Preheat? with external ballast (Mine is daylight, that could be rare?)
3rd Generation: Same build as 2nd generation, except lumens listed
4th Generation: Has holes on bottom and top.
Lighting enthusiast from San Francisco.
I upload plenty to here, YouTube, and Instagram
!! If I am quiet here, check either my Instagram or my YouTube !!
UChBXesrxSalDTp79uMtfDvA
Re: GE Helical Generations « Reply #1 on: May 20, 2022, 02:41:11 AM » Author: WorldwideHIDCollectorUSA
All of these CFL lamps use integrated electronic ballasts.
N3210
lightbulb
Re: GE Helical Generations « Reply #2 on: May 20, 2022, 11:12:08 AM » Author: N3210
Mine (with external ballast) starts differently. How can it be electronic ballast? (I have video)
Patrick
Webmaster
LightingGallery
Re: GE Helical Generations « Reply #3 on: May 20, 2022, 11:42:57 AM » Author: Patrick
What do you mean by external ballast?  Here's a spiral CFL with a non-integrated ballast, but they aren't common.
Patrick C., Administrator
N3210
lightbulb
Re: GE Helical Generations « Reply #4 on: May 21, 2022, 02:29:50 AM » Author: N3210
I define "external ballast" as this:
Re: GE Helical Generations « Reply #5 on: May 21, 2022, 03:56:59 AM » Author: dor123
The ballast is still integrated into the lamp. External ballasts CFL is the PL lamps.
N3210
lightbulb
Re: GE Helical Generations « Reply #6 on: May 21, 2022, 12:35:11 PM » Author: N3210
Ohhhhhh... Then again, I wonder why my Helicals start differently though? Different ballast technology?
« Last Edit: May 21, 2022, 06:46:44 PM by N3210 » Logged
Re: GE Helical Generations « Reply #7 on: May 22, 2022, 12:45:50 PM » Author: James
The first helical CFL was a GE prototype of 1976 without ballast, see here.  It took a further twenty years to develop the manufacturing equipment, and GE announced the Heliax lamps for sale in 1996.  They were also pin-ended types intended to replace triple-tube CFL lamps.  However, due to manufacturing difficulties very few made it to market before they were quickly discontinued.
Around 2005 GE tried again, and launched a self-ballasted Heliax lamp.  It was made possible thanks to an improved machine developed by its Hungarian Tungsram division, and they were sold in the USA for several years.  See example here.  Nots its elegant shape how the diameter of the spiral varies to create a ball shape like an incandescent lamp.  This was probably GE’s first truly commercial spiral lamp.
It wad expensive to make, and within a year or two GE began sourcing hand-made spiral lamps from Chinese factories.  The first were made in T4 glass, and around 2008 they shifted to T3 and T2 with a major size reduction.
« Last Edit: May 22, 2022, 06:04:54 PM by James » Logged
Patrick
Webmaster
LightingGallery
Re: GE Helical Generations « Reply #8 on: May 22, 2022, 02:47:03 PM » Author: Patrick
Lights of America states that they introduced their "Twister Bulb" in 1997.  Their early spiral CFLs were stamped "Made in USA" though whether they actually formed their own glass or imported tubes they merely assembled, that I don't know.  LOA has a reputation for exaggerating the extent to which their products are made domestically, as well as the lumen output and average life.  I see their website is gone, so I wonder if they've finally gone out of business.  The quality of their LED products was arguably even more dubious than their fluorescents, and they'd pretty much disappeared from major retailers over the past decade.
Re: GE Helical Generations « Reply #9 on: May 23, 2022, 02:58:07 AM » Author: AngryHorse
Interesting, I never noticed the ‘ball’ shape on the GE before!, question is though, to keep this shape how did they remove the spiralling mantle from the tube once it was coiled?  :D
Re: GE Helical Generations « Reply #10 on: May 23, 2022, 06:46:31 AM » Author: Mandolin Girl
They might have used a high temperature silicon bladder which they deflated.  :wndr:
Re: GE Helical Generations « Reply #11 on: May 23, 2022, 07:27:26 AM » Author: AngryHorse
That sounds plausible yes, I’ve only ever seen the rotating metal ones?
Re: GE Helical Generations « Reply #12 on: May 23, 2022, 08:08:33 AM » Author: dor123
I think they were only an American importer of Chinese lamps, that stamped their brands of the lamps they were imported.
Re: GE Helical Generations « Reply #13 on: May 23, 2022, 06:20:03 PM » Author: James
Good question about how they removed the former!  A silicone material would be destroyed at almost a thousand degrees lower so a steel structure was certainly used. I believe it was a 3 or 4-part mould allowing it to be dismantled and removed.
I have the same view about LoA.  For many people in the industry who knew them, the L meant something other than
lights!
Re: GE Helical Generations « Reply #14 on: May 23, 2022, 06:23:36 PM » Author: Mandolin Girl
Thanks James, I knew you would know, if I'd stopped to think properly I would have realised that silicon wouldn't stand up to the rigours of the process.
