Author Topic: The type of lantern you use for home lighting  (Read 3287 times)
bulb_tester2009
The type of lantern you use for home lighting « on: June 12, 2022, 09:17:01 PM » Author: bulb_tester2009
At home, our ceiling lamps usually use ring fluorescent tubes, LED lamp plates. The vast majority of LED bulbs are used in downlights and pendant lamps, and a very small number of are original CFLs.
« Last Edit: June 12, 2022, 09:21:12 PM by bulb_tester2009 » Logged
My interest in lights began when I was a child
One of the few Chinese users in LG
:hps: Lamp bases in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
:hps: Poor quality lamps in my collection are prohibited. Most of them have been used for my destructive experiments and ballast tests.
UChBXesrxSalDTp79uMtfDvA
Re: The type of lantern you use for home lighting « Reply #1 on: June 15, 2022, 12:22:50 AM » Author: WorldwideHIDCollectorUSA
In my apartment, most of the lighting that I use for home lighting is mostly a mix of HID and fluorescent lighting running on preheat circuits with a few electronically ballasted CFL lamps and a 4 lamp instant start electronic ballasted F32T8 wraparound fluorescent tube fixture with some banned GE F32T8/SP50 tubes and GE F32T8/SP65 tubes.
bulb_tester2009
Re: The type of lantern you use for home lighting « Reply #2 on: June 15, 2022, 11:07:17 PM » Author: bulb_tester2009
For China's electricity bill, this is a waste of money, so in China we have gradually tended to LED, and all fluorescent tubes will eventually be used for my testing.
Re: The type of lantern you use for home lighting « Reply #3 on: June 15, 2022, 11:09:16 PM » Author: WorldwideHIDCollectorUSA
In general, the shift to LED lighting is a global phenomenon. It seems inevitable that there will be a point where any light source that is not LED will become hard to find.
bulb_tester2009
Re: The type of lantern you use for home lighting « Reply #4 on: June 16, 2022, 07:52:13 PM » Author: bulb_tester2009
So before they are eliminated, let's stock up on some.
Re: The type of lantern you use for home lighting « Reply #5 on: June 17, 2022, 04:30:17 PM » Author: AngryHorse
KITCHEN:
10 x Diall 5 watt GU10 LED (top of units) 4000K
10 x Diall 5 watt GU10 LED (bottom of units) 3000K
2 x GE 20 watt CFL (main lighting) 2700K
3 x Eton 5 wattt GU10 LED (food prep area) 6500K
HALLWAY:
1 x 14 watt Philips Genie CFL 2700K
LIVING ROOM:
6 x Sylvania 4 watt LED filament lamps (main lighting) 2700K
3 x Sylvania 4 watt LED filament lamps (ceiling fan) 2700K
STAIRWAY LANDING:
1 x 18 watt Philips Genie CFL (main light) 2700K
1 x 8 watt Philips Softone CFL (night light) 2700K
BATHROOM:
2 x Megaman 11 watt CFL (main lighting) 2700K
1 x Energetic 3 watt LED (night light) 2700K
BIG BEDROOM:
2 x GE 2D fluorescent 3500K
SMALL BEDROOM:
6 x GE GU10 LED 3000K
OUTSIDE LIGHTING:
1 x Diall 12 watt LED filament lamp 2700K
1 x Diall 13 watt LED filament lamp 2700K
2 x 8 watt Philips Genie CFL 2700K
« Last Edit: June 18, 2022, 02:51:22 AM by AngryHorse » Logged
bulb_tester2009
Re: The type of lantern you use for home lighting « Reply #6 on: June 29, 2022, 08:13:00 PM » Author: bulb_tester2009
KITCHEN:
HALLWAY:
LIVING ROOM:
STAIRWAY LANDING:
BATHROOM:
BIG BEDROOM:
SMALL BEDROOM:
OUTSIDE LIGHTING:
Kitchen:Opple 12W LED module
Balcony & living room & master bedroom & secondary bedroom:Opple LED ceiling lamp
Toilet 1: Philips Essential TL5C 22w/865
Toilet 2: Miscellaneous brand T5 circular tube 22W
Mirror front lamp:Opple T5 21W 865/840
Hallway: 3*Philips Genie 5W/827+3*Philips Genie 5W/865
Living room:Opple double colour temperature ceiling lamp+Opple LED bulb 8W/860*3
My room:3*Old Philips Essential 8W/865 CFL+IKEA SOLHETTA 6W/940 LED high CRI bulb
All CFL and circular tubes will be replaced by LED, and the corridor lamp is expected to be replaced by Philips essential led 2.8W 830/865.
« Last Edit: June 29, 2022, 08:20:49 PM by bulb_tester2009 » Logged
Molly
The wild Lampent hates LEDs!
mollylovesreptiles UChSn_GuLy2eE43RAiEFyoEw mollylovesreptiles https://tinyurl.com/yc4p2
Re: The type of lantern you use for home lighting « Reply #7 on: July 08, 2022, 12:02:06 PM » Author: Molly
Fluorescent and LED. We have a very small amount of boob lights and ceiling fans.
If you want to use any of my photos, please ask me for permission, and make sure to add credit. Thank you! :love:
Re: The type of lantern you use for home lighting « Reply #8 on: July 08, 2022, 12:10:36 PM » Author: dor123
In my room at my hostel, I uses Hyundai Baguette 102 fixture for one 21W T5, and Ventral tracklight for 70W double ended MH lamp. I have a computer/table/desk lamp with E27, which now have Sunlight 15W full spiral 2700K CFL and above my bed, a NISKO made meltlight with Eltam series choke and a Sylvania Lynx-S 9W/827 CFL.
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Re: The type of lantern you use for home lighting « Reply #9 on: July 13, 2022, 09:44:43 AM » Author: HIDLad001
We use recessed can lights with LED bulbs in them. Just to clarify, I encourage LED lightbulbs in the home, as long as they are a standard shape, or flood, and use a screw / bayonet base. I don't like the fluorescent retrofits.
Molly
Re: The type of lantern you use for home lighting « Reply #10 on: July 13, 2022, 01:01:09 PM » Author: Molly
We have recessed lights as well, only in the kitchen though
