Author Topic: What was the biggest lamp you ever seen in a streetlamp?  (Read 7079 times)
magslight
What was the biggest lamp you ever seen in a streetlamp? « on: January 11, 2010, 02:34:04 PM » Author: magslight
I only saw as biggest lamp a Siemens Klassiker with 400w HQL. I know this is nothing in comparison with lanterns ,which are used in the USA.
lite_lover
Darren
GoL darren.harward
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #1 on: January 11, 2010, 02:56:35 PM » Author: lite_lover
Here in Western Canada the biggest lamp I've seen is 400W,nothing higher here except for parking lots,most are 100W or 150W HPS,and 250W to 400W HPS on the highway.
Highest mecury I've seen 400W (before changeover to HPS)
Highest HPS 400W in: Sylvania Powerlite B2255,McGraw Edison Unidor 400,Hubbel RLG
Joseph just reminded me...We do have some high mast fixtures here as well along the #1 or 401 Freeway at some of the interchanges which have several 1000W HPS fixtures on each mast,three of the masts that were installed have never been used :o ???, which are closer to where I live,that must be why I forgot about them.  :)
« Last Edit: January 11, 2010, 03:52:06 PM by lite_lover » Logged
The brighter the better.
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #2 on: January 11, 2010, 03:16:54 PM » Author: joseph_125
The highest I've seem here in Eastern Canada-Ontario is 1000W HPS which is used in some highway highmast fixtures. For regular streetlighting the highest I've seen is 400W HPS,
The highest mercury would possibly be 400W(I don't think 700W or 1000W lamps were used here). I've seen 400W MH fixtures in Quebec but the highest in Ontario I've seen is 250W
lightman64
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #3 on: January 22, 2010, 08:21:07 PM » Author: lightman64
I have seen 1500w Metal Halide, in a parking lot light. I actually have a ballast from one and it weighs 30 pounds!
chapman84
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #4 on: January 22, 2010, 09:01:32 PM » Author: chapman84
1000 watt mercury vapor (and I own one too.)
Rob
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #5 on: January 24, 2010, 10:14:04 AM » Author: Rob
SOX 180w LPS lamp. and 250w HPL-N MV lamp.
Xytrell
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #6 on: January 24, 2010, 01:43:41 PM » Author: Xytrell
I THINK the local fleet farm has 1KW HPS. There are only four of them in the entire lot, so they must be pretty beefy. Wait... I guess that doesn't qualify as a street lamp, does it? In that case, I've only seen 400W MH and 400W hps.
hotrestrike
Re: What was the biggest lamp you ever seen in a streetlamp? « Reply #7 on: March 14, 2010, 11:12:32 PM » Author: hotrestrike
The main roads in my area used to have 400 and even 700w mercury lamps - now 400w HPS. Even the smaller arterials use 250w HPS and I have even encountered residential neighborhoods using 200w HPS! Downtown Seattle uses 400w HPS cobraheads plus 150w HPS (x3) for sidewalk lighting and 400w HPS floods to light storefronts & bus shelters. Overkill - I think - although the ultimate winners are the local shipyards with huge clusters of 1000w HPS floods, with as many as 16 per pole.
Highways commonly have 400w HPS lamps but some high-mast lighting have used 1000w lights with as many as six fixtures on one pole!
Residential neighborhoods are typically 100w HPS. Even residential yard lights can be easily found at hardware stores with 150w HPS lamps. Only in America - where we're aiming to be bigger & brighter than the rest of the world.
