Author Topic: Can slimline sockets fit into T8 tandem fixture socket tracks?  (Read 2023 times)
Burrito
McGraw Edison Rotoshields
Can slimline sockets fit into T8 tandem fixture socket tracks? « on: July 05, 2022, 12:38:41 AM » Author: Burrito
I've had thought for a while now regarding if regular slimline sockets can fit into the socket tracks of a T8 fluorescent tandem fixture. I'll fetch pics tomorrow. The spaces of the T8 socket is a bit narrower then the slimline sockets are, Do i need to do cutting? Thanks!
Re: Can slimline sockets fit into T8 tandem fixture socket tracks? « Reply #1 on: July 05, 2022, 04:16:16 AM » Author: joseph_125
I did a bi-pin to slimline conversion a a few weeks ago. The socket cutouts for slimline are deeper but are also slightly wider compared to the ones for bi-pin lamps. A steady hand and some tin snips should get you close to the cut out you need, a file can be used to clean up any burrs and the corners.
On some commercial grade striplights, you can flip the socket brackets around for slimline so no cutting needed.
Burrito
Re: Can slimline sockets fit into T8 tandem fixture socket tracks? « Reply #2 on: July 05, 2022, 08:47:30 AM » Author: Burrito
Good to know, Thanks!
Burrito
Re: Can slimline sockets fit into T8 tandem fixture socket tracks? « Reply #3 on: July 05, 2022, 02:39:02 PM » Author: Burrito
Here are the sockets.
Re: Can slimline sockets fit into T8 tandem fixture socket tracks? « Reply #4 on: July 05, 2022, 02:55:06 PM » Author: joseph_125
Here's the completed fixture I converted.
Also if you have a small coping saw for metal, that will probably get you a cleaner cut than snips. In production the holes would be punched out with a die but they're usually custom made for that specific fixture model.
Burrito
Re: Can slimline sockets fit into T8 tandem fixture socket tracks? « Reply #5 on: July 05, 2022, 02:56:44 PM » Author: Burrito
Interesting, I got none of those materials, but i'll figure a way around it
