Author Topic: Question About Lamp & Ballast Compatibility  (Read 3096 times)
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Question About Lamp & Ballast Compatibility « on: July 27, 2022, 01:24:18 AM » Author: 108CAM
I'm thinking of purchasing some 175w MV lamps so I can have some extras for my collection. I plan to run them with an Atco OMB175 ballast designed for 175w MV lamps. This ballast runs off Australia's 240v 50hz mains power supply.
I'd like to know if a 175w MV lamp intended for use with a North American 120v 60hz H39 ballast will work safely on an Australian 240v 50hz Atco OMB175 ballast. Remember not everyone knows and understands the meanings of technical terms so a simple yes or no would be great.
1925-2002
Bring back the AJF Zodiacs!
Re: Question About Lamp & Ballast Compatibility « Reply #1 on: July 27, 2022, 02:23:00 AM » Author: Medved
These medium or lower power MV lamps are the same spec worldwide, so it should work properly...
108CAM
Re: Question About Lamp & Ballast Compatibility « Reply #2 on: July 27, 2022, 02:24:21 AM » Author: 108CAM
Thanks
1925-2002
Re: Question About Lamp & Ballast Compatibility « Reply #3 on: July 31, 2022, 01:57:28 PM » Author: Mandolin Girl
Our American friends have it easy with the ANSI codes.  :hps: :mv: :emh: :lps:
bulb_tester2009
Re: Question About Lamp & Ballast Compatibility « Reply #4 on: August 02, 2022, 08:15:04 AM » Author: bulb_tester2009
I also have another confusion, which is why one Philips BPL13 ballast cannot start one GE Biax™ F13BX, while two Philips BPL13 ballasts in parallel can start two GE 13W Biax™ F13BXs?
My interest in lights began when I was a child
One of the few Chinese users in LG
:hps: Lamp bases in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
:hps: Poor quality lamps in my collection are prohibited. Most of them have been used for my destructive experiments and ballast tests.
Re: Question About Lamp & Ballast Compatibility « Reply #5 on: August 02, 2022, 09:12:53 AM » Author: Medved
Certain lamp wattages (mainly with those nonballasted quad- or six-tube CFL's) are available with two electrical specs, not compatible to each other. They then usually differ in the base (different position of the keying notches and pins,...). I think the 13W is indeed one of them.
No idea for the reason why.
