Author Topic: Any british members know anything about this one?  (Read 4739 times)
RadiantMV
Any british members know anything about this one? « on: November 06, 2022, 05:16:15 PM » Author: RadiantMV
Found this on ebay and am honestly considering bidding on it as it’s quite cheap. It looks to be GEC but is labeled as “whitecroft” and searching that up doesn’t yield much information.
https://www.ebay.co.uk/itm/134317140496
UChBXesrxSalDTp79uMtfDvA
Re: Any british members know anything about this one? « Reply #1 on: November 06, 2022, 07:27:51 PM » Author: WorldwideHIDCollectorUSA
It seems like it runs either 80w or 125w mercury vapor lamps.
RadiantMV
Re: Any british members know anything about this one? « Reply #2 on: November 06, 2022, 08:05:40 PM » Author: RadiantMV
Yeah if i get it I’ll probably run 100 watt in it since the ballast for those is much easier to find in North America compared to those other wattages.
Re: Any british members know anything about this one? « Reply #3 on: November 06, 2022, 08:39:27 PM » Author: wide-lite 1000
 Other than the Royce Thompson P/C mounted on the side , it appears to be gearless . The center label does mention 70w so maybe it's designed for a 70w SON lamp with a remote ballast ??? It also just has a "-" where a voltage and hertx rating should be .
Re: Any british members know anything about this one? « Reply #4 on: November 07, 2022, 02:33:37 AM » Author: AngryHorse
This is indeed GECs Z8896/7 lantern for 80/125 watt mercury or 70 watt HPS, we had these at our school running 125 watt mercs in the 80s  :D
It later went on to be listed as Siemens, then WRTL
RadiantMV
Re: Any british members know anything about this one? « Reply #5 on: November 07, 2022, 11:52:08 AM » Author: RadiantMV
I find it interesting that the UK kept using remote ballasted clamshell style luminaries for so long. Here in North America similar lanterns were discontinued in the early 60s.
Re: Any british members know anything about this one? « Reply #6 on: November 07, 2022, 02:14:28 PM » Author: AngryHorse
Not just mercury either!, we were still installing column mounted gear for SOX lamps in the mid 80s!  :D
Re: Any british members know anything about this one? « Reply #7 on: November 07, 2022, 02:35:50 PM » Author: joseph_125
I've always found that interesting. Over here the the manufacturers were promoting the time and labour savings of a internally ballasted luminaire/cobrahead in trade ads from the late 50s, and by the mid 60s, most remote ballasted roadway luminaires were discontinued with customers looking for remote ballasted option being directed to order a "empty" cobrahead.
Our remote ballast installs were typically different too, often opting for can shaped ballasts mount to the exterior of the pole near the arm or in a add on transformer base.
RadiantMV
Re: Any british members know anything about this one? « Reply #8 on: November 14, 2022, 06:42:37 PM » Author: RadiantMV
Update: for some reason this listing went absolutely crazy and i lost to a huge bidding war at 5 seconds left. In the meantime i did manage to snag an Eleco GR100 90 watt SOX luminaire that was also going for quite cheap.
Re: Any british members know anything about this one? « Reply #9 on: November 14, 2022, 07:42:39 PM » Author: joseph_125
Ahh, too bad about the losing the original light but a 90w SOX luminaire is a pretty good find too in itself IMO.
