Author Topic: H22 Ballast?  (Read 2307 times)
Lamp_o_watcher
We are the Sultans... We are the Sultans Of Swing!
Nido's Hardwar3 @Lamp_o_watcher
H22 Ballast? « on: August 15, 2023, 06:10:32 AM » Author: Lamp_o_watcher
I saw a label on a Westinghouse 175 watt MV bulb that said H22 or H39 ballast type. I know what H39 is but I have never heard of H22... is there such a thing?
You are young and life is long, and there is time to kill today
And then one day you find ten years have got behind you
No one told you when to run, you missed the starting gun
Re: H22 Ballast? « Reply #1 on: August 15, 2023, 10:20:34 PM » Author: wide-lite 1000
 H22 was par of an old rating system . Just as the modern 400w H33 was originally called H1 .
Re: H22 Ballast? « Reply #2 on: August 16, 2023, 07:18:02 AM » Author: joseph_125
Correct, I think MV were the only HID lamps that received a new ANSI code though. 100w used to be H-4.
mefurd98
Avid collector of old consumer grade lighting.
Re: H22 Ballast? « Reply #3 on: August 16, 2023, 11:16:45 PM » Author: mefurd98
Interesting, I didn’t know this. Does anyone know the reason they changed codes?
Re: H22 Ballast? « Reply #4 on: August 20, 2023, 05:49:21 PM » Author: James
I believe it happened around the time that the US mercury lamps changed to use the newer Osram emitter material for the electrodes.  Since the lamps started more easily during life it was possible to make smaller and cheaper ballasts with lower open circuit voltage.  But those could only start the newer lamps and not the original types having thorium emitter - therefore the ballast codes were changed, to indicate that older lamps would not work on the newer ballasts - however the newer lamps could function reliably on the older ballasts, and were therefore marked with both ballast codes for many years until the original ballast types had been mainly replaced.
Re: H22 Ballast? « Reply #5 on: August 20, 2023, 06:59:20 PM » Author: wide-lite 1000
 Interesting ! I didn't know that .
Re: H22 Ballast? « Reply #6 on: August 20, 2023, 07:58:43 PM » Author: sol
Ok, going on a limb here, would the old H22 ballasts work at least somewhat reliably with M57 metal halide lamps ? I believe the difference between H39 mercury and M57 MH ballasts is that the MH has a higher OCV, but maybe the H22, while higher than the H39, might not be enough.
