Author Topic: High lumen LED light fixtures that come with replaceable corn cob lamps?  (Read 9471 times)
UChBXesrxSalDTp79uMtfDvA
High lumen LED light fixtures that come with replaceable corn cob lamps? « on: November 11, 2024, 11:29:55 PM » Author: WorldwideHIDCollectorUSA
I wonder if there are any manufacturers that make any LED fixtures intended to replace HID fixtures that are designed with replaceable corn cob lamps in mind.
For example, are there LED street lighting luminaires or high bay luminaires that are specifically designed to use replaceable LED corn cob lamps?
I am asking this because I have a feeling that the lighting industry wants to outright ban any socketed outdoor lighting fixtures that are intended to replace HID luminaires and feel intense concerns over the amount of electronic waste that is created from having to dispose of integrated LED luminaires.
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #1 on: November 12, 2024, 06:17:51 AM » Author: Baked bagel 11
I don't know of any fixtures of that style. I think that COB or a SMD panel is cheaper and more efficient than having a lamp and a reflector system.
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #2 on: November 12, 2024, 04:07:34 PM » Author: WorldwideHIDCollectorUSA
I just have a worry that E39 and E40 lampholders may someday be very hard to find due to the widespread adoption of integrated LED fixtures.
fluorescent lover 40
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #3 on: November 12, 2024, 08:09:03 PM » Author: fluorescent lover 40
Not street lights, but I believe Feit Electric and Commercial electric made yardblasters that come with just a E26 socket and the LED cob lamp. The Feit Electric had a different style and the Commercial Electric one is based on the 65w CFL ones with the PC integrated to the ballast and facing the front of the head.
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #4 on: November 12, 2024, 08:12:57 PM » Author: WorldwideHIDCollectorUSA
I am wondering if the future of E39 and E40 lampholders is uncertain and whether there will be a point when corn cob retrofit lamps become discontinued due to the dwindling numbers of socketed fixtures in existence?
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #5 on: November 16, 2024, 11:10:56 AM » Author: Cole D.
Yes, I have a Commercial Electric bucket light as you describe, with a medium based socket and LED bulb. It does look like the ones that had the CFL bulb.
Baked bagel 11
Tom
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #6 on: November 21, 2024, 02:28:18 AM » Author: Baked bagel 11
@Cole D.- Do you have a picture of that?
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #7 on: November 21, 2024, 06:31:41 AM » Author: Cole D.
I don’t think I have a picture of it in my gallery yet.
Richmond2000
120V 60HZ
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #8 on: November 24, 2024, 11:38:12 PM » Author: Richmond2000
functionally a "COB" is a costly compromise VS dedicated panel / actual chip on board COB units with a LENS assembly like the AEL ATB S/M/L and the COOPER streetworks products
the existence of the sockets I believe will last a while but will get harder and harder to "retail" purchase as demand falls off as lamp based fittings get less common and lamps themselves go out of availability
even right now to keep a HPS-SON fitting going using modern lamps is quite costly with low life expectancy of NEW lamps and high purchase prices making the toss and replace the fitting a ever more cost effective task
Re: High lumen LED light fixtures that come with replaceable corn cob lamps? « Reply #9 on: December 04, 2024, 12:20:30 AM » Author: WorldwideHIDCollectorUSA
I have recently discovered that the company known as “Filamento” has apparently designed a number of high bay luminaires specifically designed for replaceable LED lamps.
Another nice thing about the company is that they have designed their LED retrofit lamps to be used on pretty much any type of HID ballast regardless of whether it is CWA, HX, or simple choke or without a ballast at all. Additionally, the LED retrofit lamps that they have designed also include a special circuit inside them to suppress the ignitor pulses from pulse start metal halide ballasts or high pressure sodium ballasts meaning that they can pretty much function as a drop in retrofit lamp without any fixture circuit modifications whatsoever.
Here is information about Filamento’s socketed HID replacement LED fixtures:
https://www.filamento.com/applications/sports-facility/
https://www.filamento.com/products/?luminaire-configurator
Personally, for me, getting LED retrofit lamps from Filamento would be nice to have since I can now choose to alternate between HID or LED in my fixtures without having to perform circuit modifications whatsoever.
Here is the information about the universal ballast compatibility with Filamento’s LED retrofit lamps:
https://www.filamento.com/applications/ballast-compatibility/
Due to the universal ballast compatibility technology that these LED retrofit lamps have, they can help preserve HID luminaires without the need to scrap them. It would be nice if they can also use this same LED retrofit lamp technology to design horizontal burning LED retrofit lamps that can be specifically retrofitted into cobrahead street lights, shoebox luminaires, or wall packs to help preserve the look of a city’s street lighting system and preserve the look of other types of traditional luminaire designs.
In my opinion, I think that cities look better when they use retrofitted cobrahead street lights instead of new integrated LED street lights.
« Last Edit: December 04, 2024, 12:50:40 AM by WorldwideHIDCollectorUSA » Logged
