Author Topic: Why are the light fixtures used on ceiling fans known as “light kits”?  (Read 3837 times)
UChBXesrxSalDTp79uMtfDvA
Why are the light fixtures used on ceiling fans known as “light kits”? « on: December 04, 2024, 04:37:59 AM » Author: WorldwideHIDCollectorUSA
After knowing that almost every time I look at light fixtures designed for ceiling fans, I almost always see them being referred to as a “light kit”. Why did electrical manufacturers decide to refer to light fixtures intended for use on ceiling fans as “light kits”?
Re: Why are the light fixtures used on ceiling fans known as “light kits”? « Reply #1 on: December 04, 2024, 05:01:16 AM » Author: funkybulb
Reason it refered as light kits  because one is it keep confusion down when shoping for a light on a celing fan
 And two is there so many lighting option for a celing fan motor bell housing and some require Assembly to install on the celing
 Fan.
Re: Why are the light fixtures used on ceiling fans known as “light kits”? « Reply #2 on: December 04, 2024, 06:55:12 PM » Author: icefoglights
Although many fans nowadays come with them, traditionally a ceiling fan was just the fan.  If you wanted a light, you picked out the style light kit you wanted to add to that fan.  Most fans that include light kits also include a light delete kit.
