Author Topic: Running 240v  (Read 18527 times)
Re: Running 240v « Reply #15 on: March 30, 2025, 09:55:13 AM » Author: RRK
What power level you are looking for? Even with rather moderate 150VA rating of the inverter you can easily run into quite extreme currents, like 15+ amps. BTW, PC power supply is not the best way to get high power at 12V, typically start to behave funky on unbalanced load when heavily loaded at 12V channel and zero current on others. There is a myriad of proper modular 12V bricks of necessary power out there for cheap. Go 24V way, though if you can get 24V inverter, this means easier life with half the current.
NeXe Lights
Re: Running 240v « Reply #16 on: March 30, 2025, 12:28:18 PM » Author: NeXe Lights
I have one last question. There are some ballasts that only run on 240v, but most European inverters convert 12v DC to 220v/230v 50hz but not 240v. Would this effect the ballast in any significant way?
UChBXesrxSalDTp79uMtfDvA
Re: Running 240v « Reply #17 on: March 30, 2025, 12:30:31 PM » Author: WorldwideHIDCollectorUSA
If the ballast is a simple reactor ballast or leak transformer ballast, the lamp would probably be marginally underdriven, but within tolerable levels. In North America, some people often refer to 240V as ā€œ220Vā€ and some people refer to 120V as ā€œ110Vā€ as well.
NeXe Lights
Re: Running 240v « Reply #18 on: March 30, 2025, 12:36:48 PM » Author: NeXe Lights
OK. I'll have to do some testing with my multimeter to see what the actual output voltage is. And I have seen that some cars that have outlets on the say they are 110v or 115v instead of 120v. So maybe it is just the company of the inverter referring to 240v as 220v or 230v.
Re: Running 240v « Reply #19 on: March 30, 2025, 12:38:51 PM » Author: WorldwideHIDCollectorUSA
I have also ran some 110V 60Hz HX ballasts and 110V 60Hz preheat fluorescent choke ballasts on 120V 60Hz supplies and they seem to somewhat overdrive their intended lamps.
NeXe Lights
Re: Running 240v « Reply #20 on: March 30, 2025, 12:41:03 PM » Author: NeXe Lights
OK, will underdriving a bulb be a problem if it's a small amount? Also, would having a modified sine wave inverter affect anything with a magnetic or electronic ballast? Only asking because they are so much cheaper.
Re: Running 240v « Reply #21 on: March 30, 2025, 12:42:52 PM » Author: WorldwideHIDCollectorUSA
From my experience, I am fine underdriving lamps down to around 25% below their rated current at the most, but other collectors might disagree.
NeXe Lights
Re: Running 240v « Reply #22 on: March 30, 2025, 12:46:16 PM » Author: NeXe Lights
OK so the slight underdrive cause by running a 240v ballast at 230v or 220v shouldn't be a problem. But how bad would running a ballast on a modified sine wave be?
Re: Running 240v « Reply #23 on: March 30, 2025, 12:48:07 PM » Author: WorldwideHIDCollectorUSA
As far as I know, I have known that many collectors often say that modified sine wave inverters can damage magnetic ballasts due to the difference in waveform. Other collectors can explain further.
NeXe Lights
Re: Running 240v « Reply #24 on: March 30, 2025, 12:49:09 PM » Author: NeXe Lights
OK so I definitely will use a perfect sine wave inverter as to not damage a ballast.
Re: Running 240v « Reply #25 on: March 30, 2025, 04:42:59 PM » Author: RRK
It is a gamble. May be marginally OK with lagging type chokes and leak transformers. Long current pause will be bad for some lamps. Results will be unpredictable when used with leading and resonant circuits. Don't dare if you don't have an oscilloscope on hand to verify what's going on.
NeXe Lights
Re: Running 240v « Reply #26 on: March 30, 2025, 04:47:18 PM » Author: NeXe Lights
Yeah I'm not gonna risk it. I will definitely use a perfect sine wave inverter.
