Author Topic: What type of fixtures are used to light pedestrian underpasses near you?  (Read 44390 times)
NeXe Lights
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #15 on: June 07, 2025, 09:56:35 AM » Author: NeXe Lights
Not pedestrian, but many underpasses here in Illinois are lit by SOX fixtures, presumably with 55W bulbs, though they are slowly being replaced by LED. I haven't seen a single burnt-out bulb, surprisingly, but of course, once a bulb burns out, they won't be able to replace them unless they have some large stockpile of bulbs, which they probably do.
« Last Edit: June 07, 2025, 10:08:26 AM by NeXe Lights » Logged
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #16 on: June 07, 2025, 09:55:56 PM » Author: Baked bagel 11
Interesting, thanks for sharing.
Econolite03
Matthew E.
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #17 on: June 07, 2025, 11:20:16 PM » Author: Econolite03
I’d say the most common configuration for pedestrian underpasses I’ve seen here is typically fluorescent mounted at an angle with a diffuser. The diffusers apparently don’t need any vandal proofing.
Now for let’s say a regular underpass for motorists, MV is very common with HPS is second to that. Most municipalities still maintain them fairly well. Of course corn cobs are invading.
All Hail the GE M-400
Make
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #18 on: June 28, 2025, 02:38:21 PM » Author: Make
In Finland, mainly that style of fixtures was used, installed in many ways on ceiling and walls, on surface and recessed: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-71526 Usually they have MV lamps, sometimes HPS.
This is a very rare underpass fixture: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-160366
Nowadays, of course, a lot of fixed LEDs are used: https://easyled.fi/en/products/luminaires/pro-via/ and https://www.lumous.fi/en/product-category/bridge-and-tunnel-lighting/
« Last Edit: June 28, 2025, 04:33:20 PM by Make » Logged
Baked bagel 11
Tom
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #19 on: June 28, 2025, 08:07:19 PM » Author: Baked bagel 11
Interesting, thanks for the links!
Are the LEDs glarey at night?
Make
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #20 on: June 29, 2025, 01:57:26 PM » Author: Make
These Easyled fixtures are a bit glary. I heard they don't have any seals, so they collect dust.
Caroline
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #21 on: June 30, 2025, 08:39:52 PM » Author: Caroline
Nothing. I don't think I've ever seen an illuminated underpass other than one that's now condemned below a train station, that one had regular 4ft fluorescent fittings protected by custom built grates, only 2-3 worked and the rest was dark.
Everyone avoids them at night so they don't need lights, and if I have to go through one I carry a pocket torch, the bus route I take is pitch dark at night, because all of the wiring for streetlights was overhead and stolen by copper thieves, there's only a few privately owned glarebomb LED floodlights but they only light up garage entrances.
Public streetlights aren't too common in my country, because of arcane legal shenanigans, the section of pavement (if any) between the road and your house is technically a part of your property, so the lighting is up to you. Only state-managed buildings have proper lighting outside, trainstations, and some large parks, but that's really it.
Some neighbourhoods have agreed to use the same type of lights so they purchase in bulk and they all look the same, -awful 6500K LEDs- but other parts of the city are whatever people had: floodlights, cheap flush mount luminaires, hanging holders with, there's strings too, and some old dead linear halogens that are dark patches now.
dchen4
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #22 on: August 17, 2025, 07:37:15 PM » Author: dchen4
Not exactly pedestrian underpass, but I quite like the 5ft Sylvania Tunnel Pros, there are still plenty at Blacktown station. They would've been used in all kinds of tunnels/underpasses.
230v Nominal 240v Actual 50Hz
Baked bagel 11
Tom
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #23 on: August 17, 2025, 07:43:09 PM » Author: Baked bagel 11
Yeah, Sylvania had some pretty good underpass offerings.
Maxim
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #24 on: August 18, 2025, 10:01:43 AM » Author: Maxim
There aren't too many pedestrian-oriented underpasses around here, but the ones I have seen have had drop-lensed canopy lights in metal halide, vandal-proof and vapor-tight fluorescent lights, or Holophane Wallpackettes in MV, MH, and HPS (as well as other wallpack makes).
BT25
Vintage HID Collector
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #25 on: August 18, 2025, 04:13:48 PM » Author: BT25
Soulless LED...don't know the brand, don't care.
HID - Lighting with personality.
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #26 on: September 03, 2025, 04:48:15 AM » Author: HomeBrewLamps
None!
It is dark.
Baked bagel 11
Tom
Re: What type of fixtures are used to light pedestrian underpasses near you? « Reply #27 on: September 03, 2025, 05:34:10 AM » Author: Baked bagel 11
 :lol:
