Author Topic: Is Incandescent the most inefficient light source?  (Read 5440 times)
bydgoszczanin13
Aleksander L.
Is Incandescent the most inefficient light source? « on: April 21, 2025, 07:46:13 AM » Author: bydgoszczanin13
I was wondering if incandescent is the most inefficient light source, due to 10lm/1w to 15lm/1w. Is there any other light source that I don't know about that has less than 10lm/1w?
Mercury Vapour bulbs are the 2nd inefficient light source, right?
yes...
Laurens
Re: Is Incandescent the most inefficient light source? « Reply #1 on: April 21, 2025, 08:17:59 AM » Author: Laurens
Do you count combustion based light sources? Because my Kosmos oil lamp (which is a good lamp) puts out approximately 250w of power for approximately the same light output as an 15w light bulb.
Furthermore, it's all hard to compare. There were quite inefficient discharge lamps such as CO2 lamps in the late 19th century that were of less efficiency than "today's" high power incandescent lamps. In their own day, they may have been a moderate improvement in efficiency over carbon filament lamps but those things never caught on as general lighting because of the high voltage needed.
Neon runway lighting is on par with your average incandescent lamp.
Then you got those Nernst lamps. I have no efficiency figures for those. Carbon arc lamps are comparable to modern incandescents, but in their day they were much better than carbon filament lamps - not in the least because they offered a very high color temperature combined with power levels that could be cranked up into the kW levels, rather than a dim yellow/orange glow.
Check out www.lamptech.co.uk for actual hard data about various types of lamps that were actually in full scale production.
« Last Edit: April 21, 2025, 08:21:39 AM by Laurens » Logged
Re: Is Incandescent the most inefficient light source? « Reply #2 on: April 21, 2025, 08:28:49 AM » Author: RRK
There are also incandescent mantle combustion lights, significantly better than old plain flame light sources.
Also there are colored 'flame' carbon arcs doped with metals, which can be thought as metal halide lamps predecessors.
Re: Is Incandescent the most inefficient light source? « Reply #3 on: April 21, 2025, 08:34:47 AM » Author: RRK
Not true!
Do not write off neon sources easily! While plain lm/w figures may look unimpressive, neon red light sources are significantly more efficient in producing red light than filtered general purpose incandescents.
Laurens
Re: Is Incandescent the most inefficient light source? « Reply #4 on: April 21, 2025, 10:15:59 AM » Author: Laurens
Oh i don't doubt that filtered incandescents are worse. But just lm/w versue lm/w as if we're comparing LPS to HPS or something, makes them about on par.
Do you have any more information about the doped carbon arc lamps? I've never heard about those before but it would be fascinating to read up on them and what those were used for. I'm currently actually experimenting with exactly that, but for the purpose of doing chemical spectrography, rather than producing light.
Re: Is Incandescent the most inefficient light source? « Reply #5 on: May 10, 2025, 11:14:06 PM » Author: ace100w120v
Isn't SBMV pretty bad too? Worse than incandescent alone?
Re: Is Incandescent the most inefficient light source? « Reply #6 on: May 12, 2025, 02:18:11 AM » Author: Medved
Well, it does not. Comparing dedicated colored runway lights with unfiltered incandescents is by far not the same as "LPS vs HPS", not even the slightest.
Comparing efficiencies (efficacy is an efficiency figure, just tailored for particular field) makes sense only for the given task. By the way that is exactly the reason, why blanket statement like "incandescents are the most ineficient lamps" does not hold just by itself either, when there are quite a few applications where the IR are not the losses, but the useful output; by the way when compared by the installed power, this use is the dominant for common households (the common IR cook tops have installed power about 2..10 kW of incanmdescent sources, stoves have about 2kW top IR incandescent heater as well, while all lights together are barely 1 kW or so). And the incandescent heater sources have efficiencies in the 90% range...
So if we are talking about runway lights function, it means it has to be red only. So whatever way the light is generated, it always leads to SomeEnergy in, only red light out. And there the Neons are the more efficient, as everything beside the red is just waste losses. And it does not matter if these are IR, convection heat or yellow, green or blue light or IR radiation.
HPS vs LPS implies comparing both used as general illumination. And there all lumens (so watts of visible light, corrected for the eye sensitivity curve) count, regardless of the color (assume the metrics does not care about light quality).
Laurens
Re: Is Incandescent the most inefficient light source? « Reply #7 on: May 12, 2025, 01:43:59 PM » Author: Laurens
Thing is, i was using them as an example of a light source that i coincidentally know the approximate lm/w figures for (which is 10-15lm/w for those things).
Not as an example of the specific application.
