Author Topic: Finding Lamp Data Sheets  (Read 8061 times)
Multisubject
Finding Lamp Data Sheets « on: April 23, 2025, 11:25:37 AM » Author: Multisubject
I have recently communicated with Alex from this platform and he gave me a copy of an incredible ongoing Excel spreadsheet containing many types of lamps and their electrical specifications. One thing that it was still missing was that there weren’t many metal halide specs. I know metal halide isn’t widely considered as cool as MV or HPS because of the boring colors and picky ballasting, but I am strangely very interested.
I tried and tried to get some electrical data sheets specifically for the electrical specifications, but all I can find is boring lumens, physical dimensions, lifespan charts, etc. Where do you find electrical specifications (voltage drop and current)? I found a few but I wonder if there is a good method for searching for these.
Later I plan on opening this document to the public so that anyone with the link can view it, so you all can see the specs in a sort-of-easy way. So you don’t have to do the hard work of looking for them.
If you have any useful resources you can put them in the comments, or just tell me how to search for them in an effective way. Any tips?
Thanks!
Re: Finding Lamp Data Sheets « Reply #1 on: April 23, 2025, 03:13:32 PM » Author: RRK
Google is your friend. A search of "xxx lamp voltage current" usually yields some useful results. Other, Osram and Philips sites still have some datasheets on discharge lamps. Also, google for 'helvar ballast catalogue'.
Re: Finding Lamp Data Sheets « Reply #2 on: April 24, 2025, 04:08:14 AM » Author: Alex
Hello,
 I'm glad that sheet helped you. Regarding its origin: it was meant to extract data from the norms related to HID lamp parameters for several reasons
— access being one of them. These norms are expensive to purchase (in the three-digit range), so if you have free access through an institution, you should use it
— unscattering. The norms contain much more additional information that may be interesting for fitting designers (optical characteristics, light center, glass temperature, dimensions, etc.), but this information is generally not crucial for simply operating the lamps
— publishing. Even though I have downloaded the norms, I cannot share them legally or anonymized. My IP address and full credentials are watermarked all over them. Publishing them would also be a criminal offense, as they are intellectual property.
The groundwork includes norms such as DIN-EN 60188 (MV lamps), DIN-EN 60192 (LPS lamps), and DIN-EN 60662 (HPS lamps). I believe I still have the norm for metal halide lamps somewhere. The norm for fluorescent lamps (VDE 0715-12) I cannot access because as it is a VDE standard, and the VDE are bastards when it come to making their norms available.
Theoretically, these are available on a university computer for a university of 25,000 people, where you can view them and make notes on paper with a pen. However, downloads or pictures are not allowed, and that computer is booked out for the next months, and I don't fancy feeding that cancer 100´s of euros just for FL lamp norm...
However, apart from that, I wanted to build an extensive database for lamps to run on not the intended ballasts. So I tried to find a way to calculate it. The easiest approach is to model a lamp as a resistor, fairly close, but it does not match the impedances given for HID lamps in publications. So my next thought was a model of a nonlinear, voltage-dependent resistor with harmonic currents and ballast —> MATLAB numerical calculations can be done, but yeah…
However, the norms contain something else that is quite interesting, at least for European lamps: a ballast impedance and voltage to characterize the lamp, which makes ballast comparison very easy. That’s why I chose these as the basis.
For American lamps: due to their different control gear, I was not able to find a publication with similar data. One good source is the engineering bulletins of the major manufacturers; these can be found with some research on Google. However, I have not yet been able to find a fully compiled list of ANSI codes with lamp parameters. I do not include random lists that come up here, compiled by members without any sources noted — more on that later.
Then there are the datasheets online. From my experience, OSRAM/LEDVANCE/SYLVANIA (USA) are useless. The best are Philips; I don't have much experience with GE. Based on my experience, the standard Philips datasheet for a single lamp or similar lamps contains all the electrical parameters you need. However, there is something better. While researching data for another one of your threads, I found a "technical datasheet" where even more information is shared, including ballast impedance for operation on a 220V system like in European standards. That is the reason why there is only a single entry for metal halide lamps, which comes from that datasheet.
Of course, you also want information on older lamps than those covered by the norm: HgH or MA series medium-pressure lamps, 175W MH and HPS lamps from East Germany, some strange UV lamps, etc. Researching these lamp parameters is mainly limited to books (university libraries or expensive reprints from Springer) or private collections of very few collectors. A good starting point is James Hooker's literature site: http://www.lamptech.co.uk/Literature.htm
Sources: My preferred sources are the norms, older datasheets, and engineering bulletins. I have a certain distrust regarding datasheets because, in recent years, they have not been created by engineers but seemingly by people in marketing with questionable technological understanding. It is also very helpful to download the source document and record the source, so you know where to look for the information if later questions arise.
Why not use some "random lists from others"? Are you willing to risk damaging a rare lamp, like a HgH mercury lamp, because someone else supplied you with questionable data without a source to verify it?
A final note: AI can be a useful tool but doesn't have to be your friend. It can be used to search for documents where the information is located. However, AI gets about 50/50 accuracy on specific lighting questions for simple topics; for more specialized issues, it can surpass some members here in producing verbal litter.
Multisubject
Re: Finding Lamp Data Sheets « Reply #3 on: April 24, 2025, 07:56:21 AM » Author: Multisubject
Wow! Who knew some lamp specs were so high-security! I guess these companies need some extra money on the side so they can’t just make the specs public.  ::)
I have scrutinized this site before. Now I will do it again, this time looking for specs!
I have only found one more spec document (400W MH) and I did put the link in the document next to it so I can see it in the future.
I also found an extensive list of ANSI codes, but it is just a list of codes with wattages, no actual specs. Still sort-of useful…
I will definitely spend some more time looking for more specs, but from what I can tell, the best information comes from people from the lighting industry who have access to such documents.
Why is this such a freaking secret?!?! Why can’t these companies just share some specs here and there? I feel like I am collecting top-secret intelligence. This is a lot more annoying than I thought it would be, but I will keep trying.
Re: Finding Lamp Data Sheets « Reply #4 on: April 24, 2025, 09:13:38 AM » Author: Alex
The data is not really secret. It can be bought just like any other book, but said book is bloody expensive. And if I get acces to that book i cannot just distribute randomly for free…
You can find the data on the net but it is scattered. I found today a very good book in the library by Siemens about lamp ballasts which is not to expensive however only available in german.
Multisubject
Re: Finding Lamp Data Sheets « Reply #5 on: April 24, 2025, 10:15:27 AM » Author: Multisubject
I am honestly only really focusing on US lamps right now, I will figure out the European lamps later. I do find pretty useful documents describing specs, but most are about foreign lamps and in a foreign language.
Re: Finding Lamp Data Sheets « Reply #6 on: April 24, 2025, 05:08:09 PM » Author: RRK
Here is a Russian GOST document, homologated with IEC188. In Russian, but pretty understandable. Or you can run it through a translator. Mercury lamps, 50 to 2000W. Dimensions, voltage, current, ballast impedances.
Enjoy for free:)
Re: Finding Lamp Data Sheets « Reply #7 on: April 24, 2025, 05:12:32 PM » Author: RRK
Here is GOST based on IEC61667 regarding small wattage MH in 35-150W, and sodium compatible 250W ones with FC2 bases.
Enjoy for free, too.
Re: Finding Lamp Data Sheets « Reply #8 on: April 24, 2025, 07:55:28 PM » Author: joseph_125
The easiest way would be to purchase the standard from NEMA/ANSI but keep in mind these are mostly sold to companies, hence the large price tag of $450.
https://www.nema.org/standards/view/american-national-standard-for-electric-lamps-single-ended-metal-halide-lamps
There's also a goldmine of information on Scribd, you might be able to find a similar document there, as well some lamp manufacturers have more information on their datasheets. I think Venture has the voltage drop and I think Iwasaki used to list the electrical parameters.
Multisubject
Re: Finding Lamp Data Sheets « Reply #9 on: April 25, 2025, 07:43:13 AM » Author: Multisubject
Thank you so much! I will definitely take a look at this.
Yeah $450 is a little steep for me lol. I will check Scribd though, that sounds promising.
LightBulbFun
Re: Finding Lamp Data Sheets « Reply #10 on: April 29, 2025, 01:49:02 PM » Author: LightBulbFun
funny you should say that you can find versions of a few ANSI standards doucments on Scribd, and using a scribd downloader, I have also got em saved as PDF's
here is Mercury, Metal Halide and High Pressure Sodium
https://www.scribd.com/embeds/666245019/content
https://www.scribd.com/embeds/502241310/content
https://www.scribd.com/embeds/502241305/content
and the one for fluorescent tubes is available freely from NEMA's website (not sure if its meant to be mind LOL)
https://www.nema.org/docs/default-source/about-us-document-library/ansi-c78.81-2016-(r2022)_aspublished.pdf
an older 2014 version can be found here
https://www.lisungroup.com/wp-content/uploads/2020/02/ANSI-C78.81-2014-Standard-Free-Download.pdf
and an even older version from 2003 that still includes detailed magnetic ballast information for the F32T8's etc can be found here :)
https://u.dianyuan.com/bbs/u/19/1090596444.81-2003.pdf
I have not been able to find any European IEC versions for discharge lamps sadly, but I have found a few for fluorescent lamps
for external ballast CFL's (and Circline tubes) https://www.scribd.com/embeds/807755562/content (I would love to find the ANSI version of this if anyone has a link/PDF available!) theres also an older version of this document which was sadly pulled frob scribd recently, but includes specifications for T10 circlines, and also the HF operation of T9 and T10 circlines, which for some reason was pulled from later versions of the spec it seems for some reason? (or is at least not included in that British version) but its too big for me add as an attachment
IEC details for double-ended fluorescent tubes https://www.lisungroup.com/wp-content/uploads/2020/02/IEC60081-2002-Standard-Free-Download.pdf (I would love to find a newer version of this if anyone has that to hand)
and for special British specific fluorescent tubes not part of IEC specs
https://www.scribd.com/embeds/332671067/content
I tracked these all down, as I got tired having to traipse through different lamp catalogs and PDFs to try and find specific lamp specifications (especially as traditional lamp sources got discontinued, and websites went down and/or manufactures started pulling lamp PDFs etc)
and there was also some more technical stuff I wanted to know that is not often included in lamp catalogs, like cathode resistances/voltages, and reference ballast impedance (which is very handy to know if you have an obscure-for-the-geographical-region lamp your trying to run on local-easy-to-hand ballasts) and it also acts as a nice definitive source, especially given that sometimes you get slightly different specs if you look catalogs from different companies etc
and then finally I tracked them down just because I enjoy this sort of in depth "nerdy" detail :)
hopefully these help others out :)
Re: Finding Lamp Data Sheets « Reply #11 on: April 29, 2025, 03:56:40 PM » Author: Alex
Well, Dez, you took quite a bit of work of my shoulders. Thank you.
 I can also deliver something:
IJC7604 for japanese MV lamps
https://kikakurui.com/c7/C7604-2006-01.html
Also a shout out to BS as they are the only ones using Latex for their standard making it much more enjoyable
« Last Edit: April 30, 2025, 05:39:16 AM by Alex » Logged
Multisubject
Re: Finding Lamp Data Sheets « Reply #12 on: May 02, 2025, 08:27:49 AM » Author: Multisubject
Oh. My. Gaaahd. You are an absolute lifesaver. Thank you so much.
