Author Topic: Why is the universal 2 pin starter base NOT called “P21” outside of Japan?  (Read 2609 times)
UChBXesrxSalDTp79uMtfDvA
Why is the universal 2 pin starter base NOT called “P21” outside of Japan? « on: May 25, 2025, 08:17:33 PM » Author: WorldwideHIDCollectorUSA
After knowing that Japan refers to the standard universal 2 pin starter base type as “P21”, I have been seeing that most countries in the world do NOT seem to have have ANY name for the so-called P21 base used on standard 2 pin starters that are virtually interchangeable across virtually across all countries. Why is that so?
So far, I have found documentation that Japan does refer to the standard 2 pin starter base as “P21”:
https://www.seiwa.co.jp/en/product/ie/pdf/Lamps.pdf
https://www.akaricenter.com/chokkan/grrow/pdf/mitsubishi-fg-4p.pdf
https://kyowadenco.co.jp/wordpress/wp-content/uploads/fl-types.pdf
It just seems strange to me that the so-called P21 starter base is unnamed in most parts of the world even though I have found that Japanese P21 base starters do fit perfectly in a standard 2 pin starter socket.
