Author Topic: European 400W MH standards  (Read 2977 times)
marcopete87
European 400W MH standards « on: June 11, 2025, 08:06:02 AM » Author: marcopete87
Hi all,
recently i got some used 400W MH fixtures equiped with lamps (Disano Indio art. 1158, 25€ each).
However, i wonder why there are 2 current options for 400W versions (3.4A and 4.2A, i got 3.4A).
Does anyone have any clue and/or bulb replacement suggestions? (i bought theese because i need a lot of daylight light in a reasonably cheap way)
Thanks!
Here is a photo of a similar product (same code, different lamp option):
Re: European 400W MH standards « Reply #1 on: June 11, 2025, 08:55:06 AM » Author: dor123
Some MH lamps are designed for 400 MV ballast and some are designed for 400 HPS ballast and some can work on both.
Re: European 400W MH standards « Reply #2 on: June 11, 2025, 07:28:05 PM » Author: RRK
Historically, high power metal halide lamps were made to be compatible to mercury ballast impedance. Hence, 3.25-3.4A rating. About 1980's European manufacturers started to migrate their lamp to HPS ballast impedance, running at slightly higher current and sometimes slightly lower voltage. A huge confusion follows. Americans seems never to follow this move.
Some lamps have dual rating, but generally prefer one of them. Philips HPI-T is said to prefer mercury ballast, while Osram HQI-T /D prefer HPS. BLVs are mostly HPS only.GE/Tungrsram made different quartz and ceramic lamps for specific ballast impedance use. Asian market is flooded with some unbranded MH lamps, with no datasheets you can only to guess. Generally, 2-electrode lamps may be HPS compatible, but 3-electrode probe start ones almost always expect mercury impedance.
marcopete87
Re: European 400W MH standards « Reply #3 on: June 12, 2025, 11:43:30 AM » Author: marcopete87
Ok, thank you!
Michael
Re: European 400W MH standards « Reply #4 on: June 12, 2025, 04:03:00 PM » Author: Michael
The HPI-T for example works on 3.4A only while the more modern HPI-T PLUS is made for both, HPS and MV (4.0A and 3.4A) ballasts.
In the 90s Osram stated for their HQI-T and BT range both options HPS or MV. Later they seem to stick to HPS gear.
