Author Topic: What's the purpose of this F40T12 BL?  (Read 13765 times)
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
What's the purpose of this F40T12 BL? « on: June 14, 2025, 11:01:29 AM » Author: LightsAreBright27
I recently found a Philips Actinic BL TL40w/10 tube. Unlike my other long BL tubes, this one isn't for any scientific or medical use case, more like a bugzapper lamp. But I've never seen a bugzapper above 2ft (2x 20w). What can be the purpose of this tube?
245v 50Hz
Re: What's the purpose of this F40T12 BL? « Reply #1 on: June 14, 2025, 12:28:16 PM » Author: dor123
This is a blacklight lamp, not a blacklight blue.
These places uses blacklight blue lamps.
Such a long and high wattage blacklight UVa lamp may be used for exposing printing plates (Mainly for pad printing) and screens for screen printing.
Re: What's the purpose of this F40T12 BL? « Reply #2 on: June 14, 2025, 01:49:25 PM » Author: joseph_125
Probably a bit less common now due to LED, but before that it was common for larger saltwater reef aquariums to be equipped with a pair of Actinic Blue tubes for supplemental UV, usually paired with 1-3 MH lamps for the main lighting.
There were also some larger bug zapper units intended for use with 40w lamps, not too common though.
I think printing typically required higher outputs and usually used Super Diazo Blue tubes. 40w in 4ft isn't what I consider high power for the length either as normal 4ft T12 lamps are 40w.
Re: What's the purpose of this F40T12 BL? « Reply #3 on: June 14, 2025, 02:07:05 PM » Author: dor123
Exposing printing plates and screens can also be done with a row of F40T12/BL lamps.
Re: What's the purpose of this F40T12 BL? « Reply #4 on: June 14, 2025, 02:13:38 PM » Author: joseph_125
Yes, but then your curing space will be much larger to accommodate that where as using FR48T12/350BL/VHO/180 lamps can reduce the lamp count.
Re: What's the purpose of this F40T12 BL? « Reply #5 on: June 14, 2025, 02:51:00 PM » Author: RRK
There ARE large industrial strength bug zappers, even in 4ft tube size!
Othe uses may be photochemical, like photoresist exposure, resin cure rtc...
Re: What's the purpose of this F40T12 BL? « Reply #6 on: June 15, 2025, 08:23:44 PM » Author: wide-lite 1000
 My former neighbor had a 4' commercial bug zapper that used 2- F40T12BL tubes.
Re: What's the purpose of this F40T12 BL? « Reply #7 on: June 16, 2025, 10:55:39 AM » Author: HomeBrewLamps
Kroger uses 4 foot bug zappers.
Re: What's the purpose of this F40T12 BL? « Reply #8 on: June 20, 2025, 07:44:23 PM » Author: ace100w120v
4' zappers: Yes, they were a thing. I remember fish canneries using them on the production floor. Of course, this was before the days of LED.
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: What's the purpose of this F40T12 BL? « Reply #9 on: September 11, 2025, 02:22:04 PM » Author: LightsAreBright27
Now I realize this is indeed a bugzapper tube. I recently walked by a wholesale food market and they had a few 2x40w bugzappers hanging around. They looked similar to this image I found online:
245v 50Hz
Re: What's the purpose of this F40T12 BL? « Reply #10 on: September 11, 2025, 03:29:30 PM » Author: James
4ft and 5ft blacklight tubes are actually very common for insect traps, but not usually in public places and hence not frequently seen.  One of the most important applications is in car plants to keep insects away from the fine mechanical zones, and to prevent potentially very expensive defects if they land on wet painted surfaces.
