Author Topic: Lithium impurity in QMH lamps: Question  (Read 12431 times)
Lithium impurity in QMH lamps: Question « on: September 15, 2025, 11:44:24 AM » Author: dor123
Is there any advantage for the lithium impurity in white QMH lamps?
Re: Lithium impurity in QMH lamps: Question « Reply #1 on: September 16, 2025, 04:56:23 PM » Author: James
Yes and no.  It improves the CRI quite dramatically, but also reduces life.  Lithium iodide is far more corrosive towards quartz than sodium iodide, due to its smaller atoms which more easily penetrate and attack the silica structure.
Re: Lithium impurity in QMH lamps: Question « Reply #2 on: September 17, 2025, 04:55:26 AM » Author: dor123
Just a shame. However, the lithium that originates from the quartz isn't LiI. No?
Re: Lithium impurity in QMH lamps: Question « Reply #3 on: September 17, 2025, 04:56:30 PM » Author: James
Yes lithium is almost always present as an impurity in quartz, but often even more is added in the halide dose.
Re: Lithium impurity in QMH lamps: Question « Reply #4 on: September 17, 2025, 05:40:02 PM » Author: Ash
How does the Quartz withstand the Lithium ? I would expect it to be quite unhappy, considering that the most similar other elements are Sodium and Cesium ?
Re: Lithium impurity in QMH lamps: Question « Reply #5 on: September 18, 2025, 01:14:16 AM » Author: dor123
But is this lithium impurity have an advantage in white MH lamps, like increasing the CRI?
Re: Lithium impurity in QMH lamps: Question « Reply #6 on: September 19, 2025, 01:57:39 AM » Author: RRK
Elementary lithium from Li additive does not touch the glass much, it recombines with halogen outside the arc, forming relatively inert halide salt.
Natural lithium may present in quartz, but as some millionth fraction, not affecting the properties.
Re: Lithium impurity in QMH lamps: Question « Reply #7 on: September 19, 2025, 02:03:49 AM » Author: RRK
Natural impurity practically too weak to affect light-technical properties of the lamp significantly. Deliberate addition of Li salt sure does, and is widely practiced. Osram's American style 3000K low-power HQI-E multiband NaSc lamps is one example, also widely used in pink colored MH lamps, with or without sodium.
HQI-E 3K lamps look having pretty decent life despite obvious lithium addition, BTW.
« Last Edit: September 19, 2025, 02:08:34 AM by RRK » Logged
Re: Lithium impurity in QMH lamps: Question « Reply #8 on: September 19, 2025, 03:07:23 AM » Author: dor123
@RRK: R U sure that the Osram HQI-E 70-150W/W USA  have LiI? My Sylvania HSI-TD 70W/WDL and my Aliexpress 70W 3000K MH lamps have both Na-Sc without Li.
Re: Lithium impurity in QMH lamps: Question « Reply #9 on: September 19, 2025, 03:41:47 PM » Author: James
Actually the natural lithium impurity in the quartz has a very profound impact on the spectrum, and life.
It is very difficult to make lithium-free quartz, and it leaches out only slowly.  Actually most new lamps do not show Li spectra lines, but after some hundreds and thousands of hours burning its spectral lines become progressively stronger, and cause some CRI increase.
Re: Lithium impurity in QMH lamps: Question « Reply #10 on: September 19, 2025, 05:29:24 PM » Author: RRK
I am 101% sure, as I have seen the spectrum may times with multiple instruments. Your double-ended RX7s lamps have absolutely nothing to do with this old-school protected American-originated lamp.
Here is a hi-res spectrum catched from my HQI-E 70W/WDL
Sure there are some huge orange and deep red peaks from Li additive. Somehow Sylvania still managed to get a decent life from these despite a large lithium amount...
Btw Osram seems a bit ashamed and tends to be a bit shy :) about this lamp CRI and never publishes the exact number. No wonder why, my HP320 thinks it is just a mediocre 70-73.
Re: Lithium impurity in QMH lamps: Question « Reply #11 on: September 19, 2025, 05:51:08 PM » Author: Ash
The spectrum looks like it would be nice and pleasant light. If anything, the CRI number may indeed not do it justice
Re: Lithium impurity in QMH lamps: Question « Reply #12 on: September 20, 2025, 01:28:41 AM » Author: RRK
Well in fact the color is okay, but not great, in the agreement with 73CRI and negative R9 rating this lamp gets. I used this lamp to light up my room for some time, but removed it in favor of /940 Philips CMH which was *significantly* better, the light of HQI-E lamp was somewhat in the pinkish hue, too heavy on orange. This is a very old Sylvania originated development, some from late 1980s I believe, rather robust and long living, but is just slightly corrected NaSc lamp, color quality is 'nothing to write home about'. Probably they overdo a bit on sodium and lithium, and generally NaSc lamps have some unpleasant color, though I have a couple of NaSc lamps without Li, which give out quite nice yellowish light in ~4000K despite being just ~65CRI measured.
Re: Lithium impurity in QMH lamps: Question « Reply #13 on: September 20, 2025, 01:40:11 AM » Author: RRK
Well for me it sounds a bit counter-intuitive for lithium that is *already* present as a minor impurity in quartz walls to exit and accelerate corrosion, but of course there may be some wicked chemistry behind. Can you elaborate?
