Author Topic: Leotek has a new model, the KarbonCobra.  (Read 15579 times)
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Leotek has a new model, the KarbonCobra. « on: September 16, 2025, 06:28:30 PM » Author: Baked bagel 11
https://leotek.com/product/karboncobra-kc1/
There is a size up and down from the one linked, they can get up to 173lpw and are extremly lightweight.
NeXe Lights
Re: Leotek has a new model, the KarbonCobra. « Reply #1 on: September 18, 2025, 10:38:33 PM » Author: NeXe Lights
Geez, they had so much room to add a decent heatsink, but you know how corporate greed is. ::)
Baked bagel 11
Tom
Re: Leotek has a new model, the KarbonCobra. « Reply #2 on: September 18, 2025, 10:42:56 PM » Author: Baked bagel 11
From what I understand modern SMD LED luminaires rely less on heatsinks, take Cree's new Guideway series, that doesn't have much of a heatsink (though it does have way more diodes).
Maxim
Boiler Up, Hammer Down!
Re: Leotek has a new model, the KarbonCobra. « Reply #3 on: September 21, 2025, 12:05:28 AM » Author: Maxim
E-Cobra = EOL-Cobra
KarbonCobra = KrapCobra  :eoled: :eoled: :eoled:
fluorescent lover 40
Re: Leotek has a new model, the KarbonCobra. « Reply #4 on: September 21, 2025, 12:23:05 AM » Author: fluorescent lover 40
Just hope the KC series doesn't have plastic doors like the GCJ and GCM.
Econolite03
Matthew E.
Re: Leotek has a new model, the KarbonCobra. « Reply #5 on: September 21, 2025, 12:27:49 AM » Author: Econolite03
Seems promising, but I’d treat anything new Leotek offers with a grain of salt.
Baked bagel 11
Tom
Re: Leotek has a new model, the KarbonCobra. « Reply #6 on: September 21, 2025, 12:39:03 AM » Author: Baked bagel 11
Hopefully Caltrans uses them, that'd be interesting.
Richmond2000
120V 60HZ
Re: Leotek has a new model, the KarbonCobra. « Reply #7 on: November 09, 2025, 04:56:43 AM » Author: Richmond2000
not a bad looking design and for heatsink the top is the heatsink and that is why it is cut down compared to the gear compartment / slip fitter end
Re: Leotek has a new model, the KarbonCobra. « Reply #8 on: November 09, 2025, 10:25:30 AM » Author: Ash
SMD LEDs are not somehow different from any other LEDs. About 70% of the power turns to heat, virtually nothing of it gets out of IR (due to no parts of the light source being at high temperatures). This heat have to be removed from the LED assembly and then from the luminaire body as a whole
The only question is, what is the actual power (the heat) vs. the surfaces area to dissipate it, regardless of whether it is shaped as visible fins or not
