Author Topic: Are the Sylvania Relumina CMH retrofit lamps OCV and frequency dependant?  (Read 6764 times)
UChBXesrxSalDTp79uMtfDvA
Are the Sylvania Relumina CMH retrofit lamps OCV and frequency dependant? « on: September 22, 2025, 10:51:33 PM » Author: WorldwideHIDCollectorUSA
After reading that the European Sylvania Relumina ceramic metal halide retrofit lamps for the European market utilize a built-in inductor to help achieve significant energy savings by adding a series impedance between the mercury vapor reactor ballast and the arc tube, I also understand that reactor ballasts are often highly sensitive to variations in line voltage and AC frequency. Generally, a higher applied line voltage means the lamp draws more current while a higher applied AC frequency means that the lamp draws less current.
Ideally, I am pretty sure that these lamps in particular are generally optimized to run on European 220-240V 50Hz mercury vapor reactor ballasts.
If I was to operate the 85W or 80W Relumina retrofit lamp designed for 125W mercury vapor ballasts on a 220V 60Hz mercury vapor reactor ballast designed for 125W mercury vapor lamps, would the higher AC frequency cause the lamp to be underdriven compared to operating it on a 240V 50Hz 125W mercury vapor reactor ballast under the assumption that the ballasts are operating on the correct voltage and frequency?
Re: Are the Sylvania Relumina CMH retrofit lamps OCV and frequency dependant? « Reply #1 on: September 22, 2025, 11:22:22 PM » Author: RRK
Internal choke will have 20% higher impedance than intended, sure. I'd say the lamp will run underdriven about 10% by current on your ballast.  Hard to calculate exactly due to multiple nuances, easier to try a test run and measure the current.
Re: Are the Sylvania Relumina CMH retrofit lamps OCV and frequency dependant? « Reply #2 on: September 24, 2025, 12:40:42 PM » Author: Ash
I think it may be possible to run this lamp in the US using a HX ballast for 175W Mercury lamp
The HX ballast must be powered at reduced input voltage, to get its output current down to 125W specs (1.15A with an actual 125W lamp). Actually a bit above 125W specs, to take into account that the lamp's built in ballast have higher impedance at 60Hz. Finally, measure the lamp current and fine tune the voltage to correct it
