Author Topic: 3 or 4 lamp RS F40T12 ballast  (Read 15501 times)
Emersyn
3 or 4 lamp RS F40T12 ballast « on: October 01, 2025, 10:20:22 AM » Author: Emersyn
I was wondering if there are 3 or 4 lamp RS (electronic or magnetic) F40T12 ballasts because I'm thinking of putting an emergency ballast in my 4 lamp wrap around but there's already two ballasts in it at the moment (Advance 1x F40 HPF RS, Advance 2x F40 Electronic RS, one of the old ballasts got removed and got replaced by the single lamp one).
rapidstart_12
@rs12official
Re: 3 or 4 lamp RS F40T12 ballast « Reply #1 on: October 01, 2025, 03:06:44 PM » Author: rapidstart_12
Advance made one model of F40T12 4-lamp ballast, but it was literally just two regular F40 rapid-start ballasts in the same enclosure, and took up the same amount of space as two standard ballasts, so that’s not really a solution to this dilemma. But what’s stopping you from just drilling some extra holes for a third ballast?
Emersyn
Re: 3 or 4 lamp RS F40T12 ballast « Reply #2 on: October 01, 2025, 04:47:44 PM » Author: Emersyn
I don't know how to drill the holes, my dad probably wouldn't like that in the house, and I wouldn't have anyone to do it for me anyways
Those long ballasts must look a bit funny
Re: 3 or 4 lamp RS F40T12 ballast « Reply #3 on: October 01, 2025, 05:03:36 PM » Author: Ash
Drilling thin metal sheet is easy, it can be done with low power battery drill and a suitable bit
If you dont want a hole, then mount 2 F40 ballasts, and some slotted metal rail such as a DIN rail between the ballast screws that are facing each other. To this rail you can attach the lighter components such as EM pack, battery, capacitors etc
Re: 3 or 4 lamp RS F40T12 ballast « Reply #4 on: October 02, 2025, 02:33:48 AM » Author: Medved
Good bits for thinner sheets are the stepwise "christmass tree" drills - their long round section, with cutting just small step of the diameter at once uses to be sufficient to keep the hole clean
BT25
Re: 3 or 4 lamp RS F40T12 ballast « Reply #5 on: October 24, 2025, 11:57:57 PM » Author: BT25
Yes, they do indeed exist. I saw some at an electrical supply shop around 25 years ago...don't remember who made them and haven't seen any since.
Re: 3 or 4 lamp RS F40T12 ballast « Reply #6 on: October 25, 2025, 12:40:24 AM » Author: joseph_125
I believe the 3 and 4 lamp F40T12 ballasts were physically larger than the two lamp versions so one of them and a emergency ballast might not fit inside the same ballast channel.
Advance made a 4 lamp version: R-4S40-A-TP-AC
https://www.ebay.com/itm/205658765762
Judging from the wiring diagram it looks like it runs the lamps in two independent series pairs, it looks like the two sections can be fed separately for bi-level switching. So basically two two lamp F40 ballasts in the same enclosure. I'm kind of tempted to buy one to try out, they would be perfect inside some of my 8ft tandem F40 fixtures.
I'm not sure if a 3 lamp RS ballast was made but a 3 lamp F40 preheat ballast was made, they're not too easy to find now.
« Last Edit: October 25, 2025, 12:45:54 AM by joseph_125 » Logged
Emersyn
Re: 3 or 4 lamp RS F40T12 ballast « Reply #7 on: October 26, 2025, 06:25:35 PM » Author: Emersyn
Thanks for the link, I might get it!
Yeah unfortunately it looks like I wouldn't be able to fit another ballast in with it
Men of God
jiachao.wei.71 chao_813975447 UChyTpXvlQ8ZCfBPP_lJjubg chao990613
Re: 3 or 4 lamp RS F40T12 ballast « Reply #8 on: February 14, 2026, 07:57:17 AM » Author: Men of God
https://www.lighting-gallery.net/gallery/displayimage.php?album=4384&pos=115&pid=156403
That's ADVANCE RS-3P40-TP 3 Lamp Rapid start ballast.
我不会英文,所以我用中文,请你们用翻译网站翻译我打的字!
I can't in English, so I in Chinese, please use the translation website to translate my words!
Emersyn
Re: 3 or 4 lamp RS F40T12 ballast « Reply #9 on: February 14, 2026, 10:05:57 AM » Author: Emersyn
Oh nice! That probably was never a very common ballast...
Re: 3 or 4 lamp RS F40T12 ballast « Reply #10 on: February 16, 2026, 08:42:22 AM » Author: joseph_125
Three lamp industrials used to be more common, I could see them being used in those.
