Author Topic: Wanted: programmed start ballast for two F8T5s  (Read 21237 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Wanted: programmed start ballast for two F8T5s « on: October 01, 2025, 04:41:21 PM » Author: HIDLad001
I want to replace a crappy LC ballast in an undercabinet light
Re: Wanted: programmed start ballast for two F8T5s « Reply #1 on: October 02, 2025, 02:56:52 AM » Author: RRK
Seems to be a rare thing, but you may try some electronic ballast for 2x7-11W 4-pin PL or 2x14W T5 HE used 'off-label'. They all share about the same lamp current around 170mA. Check the system power you will get running two lamps - if it is around 18W, you are probably OK (2x8W + some ballast losses)
Patrick
Webmaster
LightingGallery
Re: Wanted: programmed start ballast for two F8T5s « Reply #2 on: October 02, 2025, 05:36:12 PM » Author: Patrick
Just curious, is there a reason you wouldn't want to go preheat/magnetic?  Is the fixture too small (smaller than this one)?
Patrick C., Administrator
HIDLad001
Re: Wanted: programmed start ballast for two F8T5s « Reply #3 on: October 02, 2025, 10:32:51 PM » Author: HIDLad001
Yeah, it is a tiny fixture and none of my preheat ballasts fit in it
Also there is nowhere for the starters to go
Re: Wanted: programmed start ballast for two F8T5s « Reply #4 on: October 04, 2025, 05:57:52 PM » Author: wide-lite 1000
https://www.ebay.com/itm/326796791336
HIDLad001
Re: Wanted: programmed start ballast for two F8T5s « Reply #5 on: October 04, 2025, 09:30:48 PM » Author: HIDLad001
Thanks! I hope the ballast is smaller than it appears in the photo. The fixture's ballast channel is about the length of an F8T5 from the tips of the pins on one side to the other
« Last Edit: October 04, 2025, 10:18:27 PM by HIDLad001 » Logged
Re: Wanted: programmed start ballast for two F8T5s « Reply #6 on: October 07, 2025, 05:48:26 PM » Author: wide-lite 1000
 It's 9"L X 7/8"W X 1" T  Mine's mounted here : https://www.lighting-gallery.net/gallery/displayimage.php?album=lastup&cat=12766&pos=181&pid=242641
HIDLad001
Re: Wanted: programmed start ballast for two F8T5s « Reply #7 on: October 07, 2025, 06:28:49 PM » Author: HIDLad001
Yeah, that definitely will fit.
Thanks!
Re: Wanted: programmed start ballast for two F8T5s « Reply #8 on: October 07, 2025, 06:42:08 PM » Author: wide-lite 1000
 No problemo !!
