Author Topic: Sodium lamp overclocking...  (Read 4514 times)
Sodium lamp overclocking... « on: October 26, 2025, 11:06:40 PM » Author: HomeBrewLamps
So I am under no delusions that this would not DRASTICALLY shorten lamp life. However I am curious how far warm up times could be reduced on a standard E26 or E39/40 based sodium lamp. hearkening back to my previous brainstorming on making a (pretty impractical) sodium flashlight. Ideally for such application you would want a xenon headlamp type warmup speed... Say we got the lamp rapidly up to 50% or 60% of it's brightness in about 3 seconds or so (arbitrary numbers obviously) with some REALLY harsh high voltage ignition pulses and current dumping into the arc tube... how short of a lifespan will we get? 1000 hours? 500 hours? 10 hours? 1 second  :eoled: :poof: :son-t: :lol:?
I assume eventually there would be a pretty violent failure at some point. but I have a rather large amount of 250 watt and 400 watt ecolux lamps that I would not really shed a tear for if they exploded in the name of science.... obviously for a flashlight a 35-100 watt lamp would probably be more practical though. Obviously the lamps would get run at their rated wattage after their initial "Forced awakening". Has destructive testing like this already been performed @James ? I can't imagine it hasn't but I am having trouble finding it if it is even publicly available....
I have a few old schematics saved from websites for DC operated HID lighting (one primarily aimed for ocean fishing use). I will have to find them at some point in the near future... but I am sure they could serve as the concrete foundation for this mad scientist abuse of innocent lamps....
In the past I definitely have been known to feed EOL 175 watt Halide lamps to my 1000 watt ballast.... In the name of pyromania mostly.
« Last Edit: October 26, 2025, 11:13:00 PM by HomeBrewLamps » Logged
Re: Sodium lamp overclocking... « Reply #1 on: October 27, 2025, 12:35:34 AM » Author: RRK
I in fact momentarily overloaded a 400W HPS lamp may be 1.5-2 times by current when playing with this ballast https://www.lighting-gallery.net/gallery/displayimage.php?pos=-237428.
It survived, nothing exploded (one advantage of HPS for this purpose is they never explode) but it got quite prominent sputtering marks at the ends of arctube. Not fatal, but noticeable. I used a cheap throwaway Chinese lamp.
Re: Sodium lamp overclocking... « Reply #2 on: October 27, 2025, 04:54:13 AM » Author: HomeBrewLamps
@RRK I did something similar with a Walmart Regent branded 175 watt mercury lamp. But on a 1000 watt HPS ballast. It was very bright. I left it on the ballast outside for about 3 hours. And then let it cool down and it still somehow worked on 175 watt gear.  :mv:
Even crap mercury lamps are more reliable than some things lol.
