Author Topic: Do we think we could ever make a reproduction?  (Read 6819 times)
stillaintjeff24
Do we think we could ever make a reproduction? « on: October 27, 2025, 12:53:35 PM » Author: stillaintjeff24
So if we ever 3d printed a shell of a certain cobra head or yard light, or even better just gutted one for the test. We take the shell, make a mold of out it, and could somehow pour aluminum into said mold, do you think we could make a replacement shells for any light we mold? :hps:
Multisubject
Re: Do we think we could ever make a reproduction? « Reply #1 on: October 27, 2025, 01:16:57 PM » Author: Multisubject
This is probably possible. Sand casting materials are relatively accessible. The amount of effort involved in this would rarely be justified, but with a few attempts you should probably be able to get a usable result.
Laurens
Re: Do we think we could ever make a reproduction? « Reply #2 on: October 27, 2025, 03:35:28 PM » Author: Laurens
In the western world, this would be prohibitively expensive. You can try to DIY, but furnace equipment isn't cheap, and you'll be doing a lot of trial and error.
Your best bet would be to ship an example to Pakistan and ask if they can cast 25 pieces based on the example you sent there. There is a shitton of tiny foundries that sand cast stuff by hand.
If you offer them 50 euro a pop, they'll likely jump on the opportunity to make a year's wages in one sale. Perhaps you can get it cheaper even, because they won't have to make a mold if you ship them the original.
Quality is not the best of course, sand casting is a rough process. IF you want it perfect, you're better off 3d scanning and CNC machining it.
« Last Edit: October 27, 2025, 03:38:22 PM by Laurens » Logged
stillaintjeff24
Re: Do we think we could ever make a reproduction? « Reply #3 on: October 28, 2025, 03:08:27 AM » Author: stillaintjeff24
Interesting… I was curious in case someone could ever make custom or rebuilds for trashed streetlights. Thank for your response!
tigerelectronics
Long live fluorescent!
UCcObKY_XCMIZZOBNWn-PC4A
Re: Do we think we could ever make a reproduction? « Reply #4 on: October 30, 2025, 03:46:26 PM » Author: tigerelectronics
It's definitely possible. With today's tools and machinery, you could literally 3D scan one, and have a CNC machine carve one straight out of a block of aluminum :)
I'm interested in the subject of reproducing old lamps myself too!
Fluorescent tube hoarder :P
stillaintjeff24
Re: Do we think we could ever make a reproduction? « Reply #5 on: October 30, 2025, 04:05:01 PM » Author: stillaintjeff24
Lamps or Streetlights?  :hps:
Re: Do we think we could ever make a reproduction? « Reply #6 on: October 30, 2025, 06:44:27 PM » Author: joseph_125
As mentioned from other comments, sand casting would be the cheapest way to do it but the casted parts aren't as high quality as what you would get from a die casted part. Now if you design for looser tolerances and then post process the casted parts by machining critical features afterwards, you could probably get something workable.
Unfortunately the NRE and tooling costs for a die cast would be quite expensive, easy to amortize over millions of units produced, not so much for a handful of units.
Reflectors are a bit harder, they were typically hydroformed with special tooling.
The glass would probably be the most expensive to remake, most luminaire manufacturers did not produce their own glass, instead subcontracting the design and fabrication to Holophane or Corning or by selecting a off the shelf design from Holophane.
Re: Do we think we could ever make a reproduction? « Reply #7 on: October 30, 2025, 11:31:05 PM » Author: RRK
I believe custom casting services are readily available in the world of artistic sculpture making. Otherwise, for many luminaires a replica case can be 3D printed from some relatively heat-resistant plastic like polyamide.
Richmond2000
120V 60HZ
Re: Do we think we could ever make a reproduction? « Reply #8 on: November 09, 2025, 04:33:14 AM » Author: Richmond2000
there are places that will make metal objects from CAD designs all mail order
the australian streetlight facebook group there was a guy trying to scan the popular models and wanted 3/4 scale home sized ones 3D printed using LED lamps for indoor lighting
there models don't use sophisticated optics systems like American SCO streetlights employ
and for classic cobras check out Alibaba in China there are some knockoff AEL 115 and M250 - I have a 115 "greenlight" induction and it is OK build quality and glass is NOT like a western one optics design
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: Do we think we could ever make a reproduction? « Reply #9 on: November 09, 2025, 04:47:36 AM » Author: Baked bagel 11
Yep, two way crossover optics over here haha.
Do you know whether they got them, I joined the group about a month ago.
Laurens
Re: Do we think we could ever make a reproduction? « Reply #10 on: November 15, 2025, 12:46:06 PM » Author: Laurens
https://youtu.be/cNv-3opP8pk
In this video you'll find a workflow for casting your own aluminium parts. This guy is making pretty high quality parts by 3d printing a copy and then making a sand mold from that. Also a bunch of outdoors lamps.
