Author Topic: Mercury-free fluorescent tube with xenon?  (Read 4089 times)
Multisubject
Mercury-free fluorescent tube with xenon? « on: November 02, 2025, 10:21:07 AM » Author: Multisubject
Obviously fluorescent tubes have mercury. And this isn't really even a problem that needs to be solved since the amount of mercury is so small (and fluorescent tubes are rapidly falling out of favor). But if we were to design a mercury-free fluorescent tube, would xenon be our best bet? I heard somewhere that xenon is used in modern-made real neon signs to excite the phosphors, but apparently it doesn't work quite as well as good old mercury metal. Obviously we would have to design entirely new phosphors and all of that jazz, but assuming we got that all figured out would this even be a viable solution? How much worse would it be efficiency-wise?
Re: Mercury-free fluorescent tube with xenon? « Reply #1 on: November 02, 2025, 11:06:07 AM » Author: dor123
Some scanners and digital copiers used mercury free CCFL and electrodeless fluorescent lamps that used xenon.
Osram also made the Planon, which was a flat mercury free fluorescent lamp based on dielectric barriers.
NeXe Lights
Re: Mercury-free fluorescent tube with xenon? « Reply #2 on: November 02, 2025, 01:16:55 PM » Author: NeXe Lights
Efficiency-wise I would imagine quite bad. Xenon has very strong IR spectral lines, this limits efficiency in even the highest wattage xenon short-arc lamps to about 40 lm/W or lower. In a low pressure discharge, the efficiency without a phosphor would probably be even worse. Xenon does have great color rendering and a color temperature very similar to sunlight. But for general purpose lighting a high CRI CMH lamp would work a lot better, as CRI can be very similar with much greater efficiency than a xenon lamp. Although better electrode design might permit higher efficiency.
« Last Edit: November 02, 2025, 03:10:25 PM by NeXe Lights » Logged
Re: Mercury-free fluorescent tube with xenon? « Reply #3 on: November 02, 2025, 05:03:24 PM » Author: RRK
The idea of making mercury free fluorescent tubes was very lucrative and actually was researched quite intensively. Low pressure xenon in fact emits quite strong UV, but at very short vacuum UV wavelengths, roughly 140-170nm. The problem with this is very high losses due to stokes shift when you convert say 150nm photon to 600mn photon you lose 3/4 of the energy. So xenon fluorescents ended up being ~2 times less efficient than mercury variants. Making hypothetical two-photon phosphor absorbing one photon at short wavelength and emitting two at longer was not fruitful.  And as we all know the proliferation of LEDs killed that all.
I did some xenon tubes in cold cathode sign tube format, generally they were somewhat dim in comparison with mercury filled variants, but with nice clean colors due to very low visible radiation of Xe. On a good side, Xe tubes are practically insensitive to environmental temperature and have impressive lifetime.
There are mass produced mercury free HPS lamps, and actual mercury free MH in the form of automotive D3/D4 lamps.
Ironically, damn EU bureaucrats actually *killed* mercury-free HPS on the grounds of poor efficiency, but allowed regular Na+Hg variants to survive!
« Last Edit: November 02, 2025, 05:06:43 PM by RRK » Logged
Multisubject
Re: Mercury-free fluorescent tube with xenon? « Reply #4 on: November 02, 2025, 05:10:32 PM » Author: Multisubject
@dor123
I did not know that, that is definitely interesting to know.
@NeXe Lights
Only 40 lm/W? That is pretty low.
@RRK
Well that explains it. Were these ever produced for the market or are there any engineering samples? I would love to see one of these. I did not know about mercury-free HPS, I would think removing mercury wouldn't make that much of an efficiency difference in HPS due to sodium being the main emitter, but apparently I am wrong.
Re: Mercury-free fluorescent tube with xenon? « Reply #5 on: November 02, 2025, 05:36:17 PM » Author: RRK
Italians played a bit with xenon sign tubes.
As for mercury-free HPS, mercury plays quite a significant role in HPS due to atomic interaction with Na. Removing it ends up with crappier color and lower efficiency.
Here is an example of some sign tubes filled with xenon. Lower tube is filled with rather high pressure of circa 50mmHg to show the 'linear discharge' effects. See characteristically dim electrode ends on the upper tube due to low visible radiation of xenon.
Multisubject
Re: Mercury-free fluorescent tube with xenon? « Reply #6 on: November 02, 2025, 05:49:01 PM » Author: Multisubject
@RRK
Nice picture! The raw gas discharge is certainly very dim, that makes the glowing phosphor look very very cool.
Re: Mercury-free fluorescent tube with xenon? « Reply #7 on: November 03, 2025, 06:12:44 AM » Author: dor123
Here are lanterns with mercury free HPS lamps: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-135003
Re: Mercury-free fluorescent tube with xenon? « Reply #8 on: November 03, 2025, 06:13:15 AM » Author: dor123
The discharge in them looks strange.
Re: Mercury-free fluorescent tube with xenon? « Reply #9 on: November 03, 2025, 07:40:33 AM » Author: Medved
Scrapping mercury containing lamps is quite tightly controlled, so even when it cost money, the release into the environment is rather limited.
The problem with lower efficacy is, electricity generation causes a lot of heavy metal emissions into the environment, It is getting better as the coal plants are gradually shut down, but still it is very high.
So the use of seemingly mercury free lamp at the end releases way more mercury and other toxic heavy metals into the environment than the use of higher efficacy mercury free lamps.
And that was the basis why the "mercury free" was not sufficient argument to allow lower efficacy limit...
Of course all that assumes the systems are really carefully designed for the required performance, I agree, the reality is usually quite far from that.
However the assumption was at least the new installations will be designed around the new lamp specifications, so there is some savings.
Re: Mercury-free fluorescent tube with xenon? « Reply #10 on: November 03, 2025, 12:39:44 PM » Author: RRK
Mercury is released assuming the country uses coal power. With hydropower like in Sweden or Norway, or nuclear like France, exactly zero mercury is released with generation, with natural gas - just some traces.
