Author Topic: f36t12/ho magnetic ballast  (Read 6999 times)
Lcubed3
MAXIMUM LUMENS!!!
f36t12/ho magnetic ballast « on: November 18, 2025, 11:55:47 PM » Author: Lcubed3
I'm looking for an F36T12/HO 2 or 1 lamp ballast. I found some lamps and I want to convert some fixtures to them. It needs to be 120v. I'm hoping someone knows the model numbers of the ballasts?
Portland General Electric: 120/240VAC @ 60Hz
Bringer of Light
Multisubject
Re: f36t12/ho magnetic ballast « Reply #1 on: November 19, 2025, 09:31:58 AM » Author: Multisubject
Here are two Advance YS-2S85-TPs. Each one can power 1 or 2 tubes. Kind of expensive but it is a pack of two ballasts.
https://www.ebay.com/itm/255543314322
Ugly1
Re: f36t12/ho magnetic ballast « Reply #2 on: November 19, 2025, 03:03:23 PM » Author: Ugly1
 The listing says 120 volts, but the ballast label is red and says 240 volts.
Multisubject
Re: f36t12/ho magnetic ballast « Reply #3 on: November 19, 2025, 03:12:49 PM » Author: Multisubject
@Ugly1
That is true, I guess I don't know how to read lol :mrg:
Lcubed3
MAXIMUM LUMENS!!!
Re: f36t12/ho magnetic ballast « Reply #4 on: November 19, 2025, 07:22:38 PM » Author: Lcubed3
Yes, I had come across that one and didn't buy it for that reason.
Bringer of Light
Re: f36t12/ho magnetic ballast « Reply #5 on: November 19, 2025, 09:26:56 PM » Author: joseph_125
Advance RC-2S85-TP is the 120v version of the ballast posted above.
For shorter lamps and for converting existing fixtures the Universal 631-LH-TC-P is probably a better option. The OCV is lower so shorter lamps aren't as likely to instant start and the shorter ballast height means it will fit into more fixtures compared to the Advance.
Re: f36t12/ho magnetic ballast « Reply #6 on: November 24, 2025, 06:58:54 PM » Author: funkybulb
 If u  have two  15  to  20 watt  preheat  chokes  and  combine the  two  in  perallel.  It will run a  F30T12
High output quite easly just unsing  two  preheat chokes
 And FS 2 starter.
Multisubject
Re: f36t12/ho magnetic ballast « Reply #7 on: November 24, 2025, 07:31:07 PM » Author: Multisubject
@funkybulb
That is a very good idea, common 18-20W chokes provide 240 ohms at 118V, while (according to my calculations) the tube needs ~125 ohms. Two 18-20W chokes in series gives 120 ohms which is close enough. Plus preheat is a lot cooler than RS in my opinion.
LightBulbFun
Re: f36t12/ho magnetic ballast « Reply #8 on: November 24, 2025, 08:20:59 PM » Author: LightBulbFun
@funkybulb
a 20W *Reference ballast* is 240 ohms, but many production ballasts are not, especially not your common 14W-20W choke some of which dont even drive a F15T8 at full power, just keep that in mind when trying to work things out like this :)
Multisubject
Re: f36t12/ho magnetic ballast « Reply #9 on: November 24, 2025, 09:35:27 PM » Author: Multisubject
@LightBulbFun
Excellent point, I did not consider that. Of course an RMS ammeter has the final say, but if you can find chokes that are just for 18-20W tubes it would probably be better than those 14-20w ones.
