Author Topic: Fluorescent Tubes Gas Fills  (Read 4242 times)
Multisubject
Fluorescent Tubes Gas Fills « on: November 24, 2025, 01:42:12 PM » Author: Multisubject
I was looking at Lamptech and some other resources at gas fill types for fluorescent tubes. All I can consistently find is that normal-output T12 tubes have approximately 3 torr of argon inside. Well that is all fine and dandy, but not all tubes are T12 NO. Are the gas fills for HO and VHO the same as NO? How about krypton tubes, are they pure krypton or a mix (and at what pressures)? I hear there is xenon and neon in some other tubes, what pressures are those at?
Does anybody have a chart or resource (or just know off the top of their head) what fills are in different diameter and different output level fluorescent tubes? I would like to add this to my public lamp spec sheet.
Re: Fluorescent Tubes Gas Fills « Reply #1 on: November 24, 2025, 11:52:08 PM » Author: dor123
European T8 lamps have krypton. European "Eco T8" and "Eco T5" lamps have xenon. American VHO T12 have Neon. F34T12 have krypton and external conductive coating.
Re: Fluorescent Tubes Gas Fills « Reply #2 on: December 07, 2025, 09:35:19 AM » Author: James
There are so many different fills, but the following basic listing is approximately correct for most manufacturers as far as I know:
T12, T8 and T5 standard : Pure argon, or sometimes argon with a very small percentage of neon and/or helium to tweak the voltage slightly.  The main exception is the British T12 8ft 100W which contains approx 25% Krypton in Argon.
T8 European energy saving tubes: Nearly all 25% Krypton, 75% Argon
T8 European extra energy saving: Still mainly argon but with varying percentages of krypton and/or even xenon.
T12 American energy saving tubes: Nearly all between 10-40% Krypton in Argon.
T12 High Output: Argon, sometimes with very small trace of neon or helium
T12 Very High Output: Usually Argon with quite high percentage of Neon and/or Helium, to raise the voltage drop and facilitate high power dissipation from low current cathodes, while also improving efficacy under high discharge current conditions.
T5 Long High Efficacy : Usually pure argon for the short tubes, and argon with between about 3% and 11% Krypton for the longer lamps.
T5 Long High Output : Argon with up to about 40% neon or neon-helium added in varying quantities, for similar reasons as in T12 VHO types.
T5 low current emergency lighting types : Argon + small amount of carbon dioxide
In all cases the pressure is low, usually between about 1 and 4 torr.  There is not a consistent trend of pressure per lamp type, this can depend on the tube length / current rating.
Re: Fluorescent Tubes Gas Fills « Reply #3 on: December 07, 2025, 09:58:32 AM » Author: dor123
If there is 40% neon or neon-helium in argon in T5 HO, why I've never seen a red glow discharges at the ends of them?
Re: Fluorescent Tubes Gas Fills « Reply #4 on: December 07, 2025, 02:18:54 PM » Author: James
Usually because there is mercury vapour present and its discharge colour overpowers that of the gasfilling.  If you place the lamp in a freezer below about -40C and remove the mercury vapour, and ionise the gas filling not too strongly, then you can see the neon discharge colour.
LightBulbFun
Re: Fluorescent Tubes Gas Fills « Reply #5 on: December 08, 2025, 01:57:56 AM » Author: LightBulbFun
looking at an official manufacturing chart I happen to have for the fill gas and pressures of T5 tubes, only the 24W and 39W HO types are Half Neon filled, the 54W 49W and 80W are still Pure Argon, and I think most of the T5 HO tubes you have looked at have been 54W ones?
(although of course there could still be manufacture to manufacture variation)
Re: Fluorescent Tubes Gas Fills « Reply #6 on: December 08, 2025, 02:08:51 AM » Author: Roi_hartmann
That's interestin. What function does the carbon dioxide has in these lamps?
Re: Fluorescent Tubes Gas Fills « Reply #7 on: December 08, 2025, 02:27:13 AM » Author: dor123
There are two 54W T5 HO lamps at my floor at my hostel. My father have two 24W T5 HO lamps in his room. Supermarkets here, used to have 49W, 54W or 80W T5 HO lamps.
Re: Fluorescent Tubes Gas Fills « Reply #8 on: December 12, 2025, 04:36:21 PM » Author: James
Good question!  I am also not entirely certain, but suspect it helps to waste some energy in the form of heat at low current operation, so as to help keep the electrodes warm enough to prevent sputtering.
Re: Fluorescent Tubes Gas Fills « Reply #9 on: December 13, 2025, 12:30:41 AM » Author: RRK
Still interesting what the real reason is! I believe that CO2 is quite reactive inside a lamp. At least, even in deliberately badly made cold cathode tubes it is consumed by electrodes in some hours of burn-in. Not 100% sure for hot cathode, but can expect CO2 will dissociate in the discharge and react with mercury vapor, precipitating elementary carbon and mercury oxide rather quickly.
Re: Fluorescent Tubes Gas Fills « Reply #10 on: December 14, 2025, 05:14:43 AM » Author: James
I would have expected the same, but do not fully understand the process.  I remember from my time in making SOX lamps at GE that every day there would be a few defects from the exhaust machine with high CO2.  They were usually caused by poor connections to the four electrode leadwires, which were then not activated at the full 5.0-6.6A for the required duration.
In case of no activation of one electrode, the C02 evolution was of course huge : the lamps would strike with the correct NeAr colour, and within a few seconds turn blueish white and extinguish.  But in case of partial activation some lamps seemed to be able to run almost indefinitely with a pale purple-pinkish discharge.  Perhaps as you say the CO2 was quickly broken down, the O2 would be gettered by the sodium and hot tungsten electrodes, and the carbon deposited in solid form.  But their discharge colour remained notably different, and these lamps were easy to detect because they ran insanely hot.  Perhaps the more stable CO was formed and some quantity of that could remain?  Of course it’s also possible that if a cathode was not fully degassed there may be some residual nitrogen contamination.
We must also remember that the first cold cathode discharge tubes of Daniel McFarlane-Moore were in fact based on fillings of pure CO2 - but indeed that quickly dissociated and complex systems were required for gas purification.  Same for the original CO2 laser invented by Bell Telephone labs.  The problem of gas breakdown was not fully solved until Sylvania’s invention of the improved CO2 gas-transport laser, which quickly became the standard design.  That completely avoids dissociation of the CO2 by mixing it with helium and nitrogen, and keeping the gas continually moving at high flow rates through the high power discharge.  But none of these features exist in the small F8T5 type emergency fluorescent lamps.  I only know about their unusual gasfilling from the manufacturing specs, but could not find any patents and the people who would have developed these all retired a long time ago.
