Author Topic: Need some fun  (Read 4409 times)
stillaintjeff24
Need some fun « on: November 29, 2025, 10:52:01 PM » Author: stillaintjeff24
I have a few magnetic ballasts, but the problem is I am bored. Anything I can do that would be fun ( except watching lamps warm up) with these ballasts without hurting any lamps or equipment?
UChBXesrxSalDTp79uMtfDvA
Re: Need some fun « Reply #1 on: November 29, 2025, 10:54:26 PM » Author: WorldwideHIDCollectorUSA
I think one idea might be to use a 70W M98 pulse start metal halide HX ballast to run a pair of 35W S76 high pressure sodium lamps in series. Or another idea is to import lamps, ballasts, and fixtures from abroad if you can save up for them. I often do that to help me from not getting bored.
stillaintjeff24
Re: Need some fun « Reply #2 on: November 29, 2025, 10:55:46 PM » Author: stillaintjeff24
I have that ballast! Just got it today* but no 35 watt High pressure sodium lamps. Too bad! I need to get some more diverse lamps.
stillaintjeff24
Re: Need some fun « Reply #3 on: November 29, 2025, 10:56:42 PM » Author: stillaintjeff24
How mad would it be to run two 400 watt metal halide lamps in series on a 1000 watt halide ballast?
Re: Need some fun « Reply #4 on: November 29, 2025, 10:58:23 PM » Author: WorldwideHIDCollectorUSA
You could run both of them in series, but I would recommend reducing the capacitor value to ensure they run properly. You would need to get a clamp meter to ensure that they are running at the proper 3.25A they require.
stillaintjeff24
Re: Need some fun « Reply #5 on: November 29, 2025, 10:59:40 PM » Author: stillaintjeff24
Isn’t one 400 3.25 amp? Or is two together 3.25 amp?
Re: Need some fun « Reply #6 on: November 29, 2025, 11:01:44 PM » Author: WorldwideHIDCollectorUSA
An individual lamp is 3.25A and each lamp is half the arc voltage drop (135V) of a 1000W M47 probe start metal halide lamp (270V). When a pair of 400W M59 probe start metal halide lamps are wired as a series pair, the arc voltage drops of both lamps sum up together at roughly 270V.
Re: Need some fun « Reply #7 on: November 30, 2025, 12:21:48 AM » Author: wide-lite 1000
 I have a few 35w HPS . I'll never use them .  If you pay shipping , I'll send them to you .
« Last Edit: November 30, 2025, 12:24:35 AM by wide-lite 1000 » Logged
stillaintjeff24
Re: Need some fun « Reply #8 on: November 30, 2025, 12:29:00 AM » Author: stillaintjeff24
How much is shipping to central Florida?
Re: Need some fun « Reply #9 on: November 30, 2025, 12:32:31 AM » Author: wide-lite 1000
 PM me your Zip Code and I can find out . I't may take me a bit tho.
