Author Topic: Impact of a cycling lamp  (Read 17533 times)
Re: Impact of a cycling lamp « Reply #15 on: November 30, 2025, 07:37:09 AM » Author: Ash
The American semi-parallel ignitors are of different topology than the European semi-parallel ignitors.
What do you mean here ?
Re: Impact of a cycling lamp « Reply #16 on: November 30, 2025, 07:42:13 AM » Author: dor123
The American semi-parallel ignitors aren't the same as our semi-parallel ignitors. They have different glow discharge on HPS and MH lamps during hot restrike.
Re: Impact of a cycling lamp « Reply #17 on: November 30, 2025, 07:54:32 AM » Author: Ash
Many possible reasons for that other than the ignitor topology. As matter of fact the topology is provided in the datasheets of SIDACs used in those ignitors (they are made by Littelfuse)
xelareverse
Re: Impact of a cycling lamp « Reply #18 on: November 30, 2025, 04:02:15 PM » Author: xelareverse
I can't imagine it's very good for the ignitor. When I used to work on streetlights (mostly being Cooper and Holophane ballasts), nearly every single fixture that I found with a bad igniter had a visibly smoked HPS lamp in it, indicating repeated cycling till the arc tube leaked. It never really seemed to harm the ballasts. I don't know that running it for a few hours would hurt it too bad, as these examples were months on end.
UChBXesrxSalDTp79uMtfDvA
Re: Impact of a cycling lamp « Reply #19 on: November 30, 2025, 06:00:30 PM » Author: WorldwideHIDCollectorUSA
@RRK, as far as I know, I am aware of superimposed ignitors for the low wattage low voltage North American high pressure sodium lamps. Examples include the Payne Sparkman ULI-050S ignitor and a few other ignitors I have mostly seen being sold in some South American countries.
See here:
https://www.lighting-gallery.net/gallery/displayimage.php?album=search&cat=0&pos=0&pid=237036
stillaintjeff24
Re: Impact of a cycling lamp « Reply #20 on: November 30, 2025, 06:02:03 PM » Author: stillaintjeff24
What wattage were those?
Re: Impact of a cycling lamp « Reply #21 on: November 30, 2025, 06:03:21 PM » Author: WorldwideHIDCollectorUSA
In the post I mentioned, the wattage ranges should be found in the description.
Re: Impact of a cycling lamp « Reply #22 on: November 30, 2025, 08:27:52 PM » Author: RRK
See here:
I said "not practical", not "not possible" ;)
Low voltage HPS have short arc lengths and until not deliberately made with high xenon pressure, require low ignition voltage with low energy. Easily satisfied just with a tapped ballast choke. Not much need to wind an extra transformer. And there is not much reason to remote ballast such a low wattage lamp....
« Last Edit: November 30, 2025, 08:39:39 PM by RRK » Logged
Re: Impact of a cycling lamp « Reply #23 on: November 30, 2025, 08:50:05 PM » Author: Ash
That would come down to luminaire designs. Britain and Israel had many small lanterns with only remote gear option, but those ultimately used 70W SON I lamps (or more commonly Mercury)
Re: Impact of a cycling lamp « Reply #24 on: December 07, 2025, 03:50:32 AM » Author: dor123
I've done a lot of hot restrikes with my Philips HID-PrimaVision PV C 70 /S CDM electronic HID ballast in my tracklight, and its ignitor still working perfect.
stillaintjeff24
Re: Impact of a cycling lamp « Reply #25 on: December 07, 2025, 03:52:39 AM » Author: stillaintjeff24
That sounds good. Where did you get your track light?
Re: Impact of a cycling lamp « Reply #26 on: December 07, 2025, 04:13:32 AM » Author: dor123
I bought it at Machsanei Teura lighting store.
Lightingeye60
Re: Impact of a cycling lamp « Reply #27 on: June 17, 2026, 08:30:49 PM » Author: Lightingeye60
Usually if a HPS lamp is left cycling the bulb will eventually just die. Sometimes they’ll burn out the ignite or cause damage to the ballast but less commonly.
Usually, the bulb just eventually will stop working.
« Last Edit: August 19, 2026, 06:08:44 AM by Lightingeye60 » Logged
