Author Topic: Are inverter A/Cs really saves energy compared to on/off A/Cs  (Read 4343 times)
Are inverter A/Cs really saves energy compared to on/off A/Cs « on: December 10, 2025, 10:47:29 AM » Author: dor123
At the HVAC Hub discord server, I asked this question, and they saying that this is true, but I don't understand how.
I only know that in on/off A/C the compressors always works at 100% speed and turned on/off, and in inverter A/C, the compressor changes its speed.
Andy
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #1 on: December 10, 2025, 03:55:35 PM » Author: Andy
Of course inverter AC is more efficient than fixed speed compressor units.
Once the room is cooled to the desired temperature the compressor just runs slowly to maintain the temperature instead of running at full speed on and off every few minutes.
This really is pretty basic stuff and should be obvious.
Think of driving a car: you don't keep flooring the accelerator and then suddenly let right off only to repeat this sequence a few seconds later to maintain roughly the same speed. If you imagine the poor fuel comsumption this would give then this corresponds to the similar reduced efficiency of fixed speed AC units in most situations.
I'm always interested in exchanging lamps with others. Send me a message if you would be interested in a trade. :)
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #2 on: December 11, 2025, 02:35:09 AM » Author: Ash
And also is wrong
Once steady state is achieved (the condition in which the inverter unit winds down), the air conditioning unit output, averaged over time, equals the heat loss (or gain, if we are in the summer) through the room walls. This heat loss depends linearly and exclusively on the temperature difference between the room (chosen by the user) and outside (determined by the weather), and insulation resistance of the room walls
The air conditioning unit has no effect on the heat loss. In case of an on/off switching unit, the hysteresis beween the on and off temperatures is way less than the temperature difference between indoors and outdoors, so in average it still has no effect on the heat loss
The air conditioning unit then must pump the same quantity of heat/time unit in or out to maintain the temperature difference constant. Heat is energy, heat per time unit is power
Consider 2 compressors with identical COP but different power. One is of the exact power required to counter the heat loss, and the other is 2x the power. The 1x one will work continuously, the 2x one will work with 50% duty cycle. Twice the power for half the time is the exact same energy
So no, thermodynamics absolutely don't confirm this basic stuff
Now let's look at the electrics :
The on/off unit has a simple induction motor. There is no principal limit on the efficiency of such motor. Having to work only in a single set of conditions (same power, same refrigerant pressures, ...) it seems obvious to optimize this motor for working at this exact set of conditions
Limiting the efficiency of such motor is only cost - If using a bigger motor with room for thicker winding, Using lowloss steel in the laminations, etc. The motor can be made to any desired efficiency
The inverter unit has a similar induction motor. It is basically a plain 3 phase motor, though most of them are not for 50/60 Hz but for somewhat higher frequency
Higher frequency allows for smaller cores and less turns in each winding (which means thicker wire can be used in the same motor size), same as in lighting ballasts. However, there are few parts that can pull efficiency down as well :
 - The stator is still made of laminations, which dont behave well above few 100s Hz. (Eddy currents, hysteresis losses, increasing loss in general)
 - The motor must work efficiently in a broad range of speeds and pressures. Is it optimised for the exact ones at which it'll run in your case ?
 - The inverter itself also got losses
Considering that 50/60Hz induction motor efficiency is typically 85%..90%, this gives the theoretical upper limit of energy you might save if the inveter and inverter powered motor would be 100% efficient
In reality, the motor is probably closer to the same 85..90% as the other motor, and the inverter has a few % left behind as well
And at the mechanics :
Running at higher speed (due to higher RPM motor) allows pumping the gas faster, or at the original speed but with smaller pistons
Smaller pistons and all the other mechanical bits have less friction surface, however they work faster for the same output, so the friction loss happens more times
Similar considerations would apply to other compressor types as well (Scroll, vane, etc)
I am not sure how the less surface vs. faster running exactly balance vs each other
Same as with the electrics, the mechanics are the same in principle and only differ in size. Both have losses of the same order of magnitude
At this point, it is no longer about any significant energy savings, but other things :
 - Cost cutting. We have reached the point where a complete inverter circuit cost is cancelled out by the savings on smaller and cheaper motor and mechanics which have to work faster. (And question remains whether the mechanics will last as long as the bigger slower running ones)
 - Blatant shoving of advanced technology everywhere it is not needed
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #3 on: December 11, 2025, 09:18:50 AM » Author: Medved
Inverter setup allows the use of more efficient motor designs (lower slip and/or even permanet magnet synchronous) that become harder or even impossible to start on a fixed frequency AC feed, so either can not be used at all without the inverter or need rather complicated starter system that is nearly as complex as the inverter.
Inverter designs do not lock the exact rpm, so there is another "knob" available for the system design allowing better optimization.
And mainly the biggest difference is related to the losses related to the second law of thermodynamics and temperature differences on the two main heat exchangers: The condenser vs ambient air and the evaporator vs the home air.
Inverter system (or any system able to vary rhe compressor power while maintaining its efficiency) reduces the power to maintain the target temperature. That means those two heat exchangers have to be transfering less power, but they remain of the same size, so the same thermal resistance (now simplifying a bit, as in reality the blowers are also throttled down). Less power on the same thermal resistance means condenser condensing the refrigerant at lower temperature so lower pressure. At the same time the evaporator gets warmer, so creating higher pressure vapor. Both of these means there is less pressure differential for the compressor to fight, hence less power demand to run it.
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #4 on: December 11, 2025, 03:24:51 PM » Author: Ash
Reduced flow and pressure delta is how the mechanical power is reduced, but how do the mechanical losses behave under those varying conditions ? Are they linear, quadratic, something else ?
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #5 on: December 12, 2025, 04:13:15 PM » Author: Medved
Depends on which losses. Mechanical friction within the compressor is related to forces, so part with rpm (inertial forces), partly to pressure difference, partly fixed per pumped volume.
Flow losses use to go quadratic with flow rate, so higher percentage with higher power.
Blow-by losses are related to just pressure differences, so percentage wise become higher at low rpm so low power.
Valve backpressure is percentage wise rather fixed.
Motor winding losses are related to torque, so pressure difference. So percentage wise become higher at lower power.
All this means each machine has obviously its most efficient operating point power level, well adjusted VFD system has that set as the minimum power setting (when the demand is below that, instead of slowing down further it turns into the classic on/off PWM regulation, just using the minimum power level when on),
The ability of VFD to go way faster so boost the power up means the system could be designed with the best efficiency at the power level barely sufficient to maintain the temperatures with the outside condition that are there most of the time. If conditions change so the system needs higher power, it can boost up so is able to keep up, even when the efficiency may actually drop. It is not an issue, because such abnormal condition usually are not present for that long time.
With fixed power system the thing has to be rated for the maximum load, but as most of the time the need is way lower, the system is stuck with that fixed power.
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #6 on: December 12, 2025, 09:35:35 PM » Author: Ash
The level at which the unit must run (including above minimum) would vary with each individual installation. It is not something the unit designer can predict with high precision
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #7 on: December 12, 2025, 11:05:38 PM » Author: Medved
It is matter of selecting particular unit power size for the given task. Along with the maximum power, to ensure it would be able to keep up with the mose demanding condition.
Obviously you won't fit exactly, but you should aim close, selecting a model/rating variant that is the closest.with its performance.
Practically it means how the manufacturer matches the exact performance with the normally used power rating category and the climate of the target market area (each exact AC designs are tailored for the given territory separately, combination of the temperatures, winds, humidity and so on, so a unit sold in one place may perform very bad somewhere else just because it is set for different climate).
Re: Are inverter A/Cs really saves energy compared to on/off A/Cs « Reply #8 on: December 13, 2025, 01:11:19 AM » Author: Ash
Max power depends on initial conditions and room size, while heat loss is insignificant at that stage. Steady state depends only on the heat loss
As unit size is chosen mostly based on its max power (to get a room from initial conditions to desired temp in wanted time), this means that the same unit may be installed in rooms with same initial conditions but very different loss
