Author Topic: Light Table Idea...? Maybe?  (Read 1795 times)
suzukir122
suzukir123
Light Table Idea...? Maybe? « on: December 22, 2025, 12:47:09 AM » Author: suzukir122
So I've got my floating shelf up-lighting idea finished, with 11 F30T12 fixtures total, currently operating in my living room.
(As of now, I still have not posted videos or pics of my up-lighting yet, but I will soon. Still need to finish adjusting/straightening out the shelves
themselves, which has proven to be very tough to achieve.) I have a plan to... possibly... create light tables for the loft. This is a tough call because
I've got 5 F30T12 fixtures that illuminate the loft already, so it's pretty bright up there if I've got all five fixtures on.
The tables would be two Lumisol 27.5" high gloss square coffee tables. Those tables are wooden tables that contain LED lights that will shine
through the tempered glass.
My plan would be to... RIP OUT... the LED lights, and then find and install single lamp cold temp magnetic Rapid Start ballasts in both of them.
Those cold temp Rapid Start ballasts will be able to run Circlines, so I'd install either a 22w or 32w Circline in both tables... but it's looking more
likely that I'd go for a 22w Circline instead, although a 32w Circline would make things easier, since the ballast should fit in the middle of the 32w
Circline, I think. (I'll be buying a 32w Circline soon just to double check to see if I'm correct. Walmart is selling them, and I think Home Depot and Lowes
are still selling them as well.)
The Circlines would definitely be Halophosphate Cool White, as that's the color theme of my living room for now until they all EOL. :lol:
Possibly easy project depending on how the table structure is, if it's anything like what I think it will be... but I'm on the fence in terms of doing this,
since I've already got a lot of light.
I'll also be using TV's/playing video games and playing board games with friends... so tables that light up, as cool as it may look, doesn't seem all that
practical... you know? Ehh... as of now it's just an idea, but so far that is my table choice for the upstairs regardless.
Interests:
Re: Light Table Idea...? Maybe? « Reply #1 on: December 22, 2025, 02:56:26 PM » Author: Ash
In a dark room the table can be lit very dimly to have the visual effect and not interfere with any screen viewing. Not sure if with a normal dimmable FL setup you would be able to get down to those levels. With some EOL dimly shimmering tubes maybe
suzukir122
suzukir123
Re: Light Table Idea...? Maybe? « Reply #2 on: December 30, 2025, 07:49:48 AM » Author: suzukir122
@Ash, I've decided that if I do turn on the TV, I'll more than likely shut the light tables off, as well as most, if not all, of the F30T12 fixtures above
the TV. This idea will only take place in my upstairs loft.
I think I'm going to go ahead and continue moving forward with this idea, but I will not be using 22w or 32w Circlines anymore. Instead, I'll either use
single lamp F14T12 fixtures, or single lamp F15T12 fixtures, using two of my single lamp Trigger Start ballasts. This won't be as bright as using 22w or
32w Circlines, and shouldn't be too bright if I do decide to use them while turning on the TV. But... if it does end up being too bright, I can easily
shut off the lights with my phone, since all of my living room lighting is in use with smart plugs.
Interests:
