Author Topic: Effects of external heating on tubular high pressure sodium lamp.  (Read 2153 times)
Effects of external heating on tubular high pressure sodium lamp. « on: January 21, 2026, 03:30:56 PM » Author: HomeBrewLamps
So i was thinking of doing one my my home brew operations again.... I want to build a compact linear HPS system with an auxillary lamp and a shutter system. I cant see this coming to fruition any time soon due to the fabrication skills that I still need to develop more.... but it has been on the books for a minute.
What I am curious about specifically is the effects of having a 1000 or 1500 watt halogen lamp in close proximity to an HPS lamp/arctube while it is warming up. Would it heat up faster noticably? Would it cause life shortening due to some form of stress I am not thinking about? The application does not call for much life anyway. 500-2000 hours is acceptable.. but i am still curious. The auxillary lamps would only function up until complete warmup and then shut down. The hps lamps in question would just be some generic tubular grow light lamps from alibaba. I would not abuse name brand lamps like this.
« Last Edit: January 21, 2026, 03:35:51 PM by HomeBrewLamps » Logged
Multisubject
Re: Effects of external heating on tubular high pressure sodium lamp. « Reply #1 on: January 21, 2026, 03:52:07 PM » Author: Multisubject
That halogen in close proximity would almost certainly help the HPS lamp warm up faster to an extent, but I don't think that is a bad thing. In theory this would actually prolong lamp life, because the less time it spends running cold, the less the electrode material sputters away. But I kinda doubt that it would be to the extent of being noticeable.
Interesting sounding project, I would love to hear more about it
Re: Effects of external heating on tubular high pressure sodium lamp. « Reply #2 on: January 21, 2026, 03:57:45 PM » Author: RRK
If you shut down halogen right at the point when HPS reaches it working temperature, I bet there is no risk of arc tube overheating, run-up time likely wil be somewhat shorter. But you must respect outer bulb and base temperature maximums. 1500W halogen emits a *lot* of heat, I heard back in 1980's there was even an idea of making a crematorium using a battery of IR halogens! ;)
Re: Effects of external heating on tubular high pressure sodium lamp. « Reply #3 on: January 22, 2026, 03:59:53 AM » Author: Ash
Both lamps emit their IR as somwhere between a "line source" and "point source". Which one of them closer describes your case depends on how close the lamps are to each other. If they are close, let's assume it is line source
Line source : Irradiation is reciprocal of the distance from the source
Point source : Irradiation is reciprocal of the distance from the source squared
Assuming an 1.5KW linear Halogen lamp within 1" from the outer glass of a 400W SON, which itself is a ~T17 tube containing a 8mm thick arctube. The arctube is about 1/2 of the length of the Halogen. (I am thinking here in terms of lamps common here, your exact lamps and sizes may vary)
So we have 2 possible paths of heat transfer by IR :
 - From halogen lamp to arctube (for wavelengths for which the SON glass is transparent)
 - From halogen lamp to SON outer glass, then separately from it to arctube (for wavelengths for which the SON glass is opaque)
We can assume (and it is close enough to reality) that the entire 1.5kW output of the Halogen is in the IR. Though i dont know how it then divides between IR for which the SON glass is transparent vs opaque
Transparent glass :
Arctube's part of the projection from the halogen :
8/(2∙50.8∙3.14)/2 = 0.013
Where :
8 - Arctube diameter
50.8 - Radius at which arctube is from the halogen
/2 - The arctube is 1/2 the length of the halogen
0.013∙1500 = 19.5
Opaque glass :
SON outer's part of the projection from the halogen :
60/360/2 = 0.083
Where :
60 - For T17 SON and a Halogen at 1" from it, the SON obstructs 60deg of the perimeter of the halogen
/2 - The SON arctube is 1/2 the length of the halogen. (The outer is more, but then not all the radiation inside will get to the arctube, so this can be still factored in here)
Arctube's part of the projection from the inside of the SON outer glass :
8/(2∙21.4)/2 = 0.093
Where :
21.4 - Radius at which arctube is from a linear strip of the glass
No pi this time as the strip of glass is flat emitter, so the intensity seen by the arctube is according to cosine law
/2 - Half of the radiation is radiated to outside the SON
0.083∙0.093∙1500 = 11.6
So, the overall power gained by the arctube from the halogen by IR will be : X*19.5 + (1-X)*11.6 , with X between 0 and 1 depending on which part of the IR spectrum the SON glass is transparent to. Worst case is X=1
So the SON arctube gains extra 20W from the irradiation
The additional delta T caused by heat transfer through other means (convection heating the SON outer, and then by IR from it to the arctube) is probably insignificant
I'd say the effect is about same as adding +20W electrically to the arctube
Re: Effects of external heating on tubular high pressure sodium lamp. « Reply #4 on: February 01, 2026, 05:07:26 PM » Author: James
The effect is extremely significant.  The luminous efficacy of an HPS lamp is determined in great measure by the amalgam temperature, which is typically set to deliver a D-line spacing of about 100 angstroms (or 120Å for the Gro-Lux types).  Higher sodium vapour pressure results in more light being wasted in the infrared, and decreased efficacy.  To measure this effect in the lab while holding all other parameters constant, we used to take simple MR16 halogen lamps and shine them onto the arc tube end where the amalgam is located, to cause modest extra heating.  Even a change of 10-20°C can drastically affect efficacy.  Hence the importance of keeping lamp dimensions and the amalgam dose weight and position absolutely consistent to avoid lamp-to-lamp variation.
In the early days when this was being investigated, and before MR16 lamps had become popular, manufacturers used to wind a small tungsten filament around the arc tube ends and provide the current to those via an extra seal in the outer bulb.  Very little heating was required to change the properties, and enable the optimum temperature to be set and recorded by pyrometry, and then tweak the lamp design until it self-heated to that point.  I do still have an example of an old 1960s HPS lamp with these end heaters.
A similar effect can of course be seen as the lamp ages - one of the primary mechanisms for voltage rise in HPS lamps (which limits their life) is the rate of end blackening around the electrodes.
For your purposes, these effects may be small enough to live with, but it would not be a good idea for a commercial product.  Even for standard HPS lamps, the lamp and luminaire standards require that when an HPS lamp is installed in a reflector, the light reflection pattern has to be optimised such that as little light as possible is reflected back onto the end seals, and that the voltage rise of the lamp in the reflector should not exceed 5V.  Otherwise the reduction of lamp life in the fixture would be much too significant.
« Last Edit: February 01, 2026, 05:33:57 PM by James » Logged
