Author Topic: Lamp electrodes with thorium oxide or lanthanum oxide?  (Read 1765 times)
Multisubject
Lamp electrodes with thorium oxide or lanthanum oxide? « on: January 22, 2026, 03:35:17 PM » Author: Multisubject
Traditionally, tungsten HID electrodes are activated with thorium oxide alloyed into the wire. This thoria doping reduces work function for lower cathode drop. This was also done for TIG welding electrodes for the same reason. Thoriated tungsten TIG electrodes are falling out of favor for other formulations, most notable lanthanated tungsten electrodes. Looking this up, it seems an identical change has been observed with HID lamps. Instead of thoria, you just use lanthanum oxide (lanthana?)
I have never heard of lanthanated tungsten outside of a welding context. Lanthanated tungsten has a higher work function than thoriated tungsten, so performs slightly worse in terms of voltage drop. Is this performance loss also observed in newer lamps that (presumably) use lanthanated electrodes?
Did this thorium to lanthanum transition ever really happen for mainstream HID lamps, or was it just for some niche lamps where lanthanum was used?
I also discovered that pieces of TIG tungsten can be used as HID electrodes because they are doped for the same purpose at pretty much the same percentages. I highly doubt I will ever find myself making my own HID lamp, but I will keep that in mind in case I ever get rich enough to have the equipment necessary to do that.
Re: Lamp electrodes with thorium oxide or lanthanum oxide? « Reply #1 on: January 24, 2026, 07:12:34 AM » Author: RRK
Main issue with thoriated TIG electrodes is that you have to grind them regularly. Though Th oxide content is relatively minute, still there is a hypothetical risk of inhaling Th containing dust, and thorium being both chemically toxic and slightly radiotoxic.
No one grinds lamp electrodes in the field like welders do, of course, so no compelling reason to degrade them to poorer emitter, IMHO.
Re: Lamp electrodes with thorium oxide or lanthanum oxide? « Reply #2 on: February 01, 2026, 04:55:05 PM » Author: James
As far as I know lanthanated tungsten was not used in HID electrodes.  As you say the efficacy is slightly lower, but we also found that we could see traces of lanthanum in the lamp spectrum.  Most lamps stayed with 2-3% thorium oxide right to the end.
What was used very widely was lanthanated molybdenum in wire and foils for HID lamps.  This showed significantly improved corrosion resistance and recrystallisation temperature, which extended the life of metal halide lamps.  It could not be used everywhere though.  I remember a big disaster when we changed to MoLa wire for the ignition antennas of HPS lamps.  It was found after some years that it suffered greater photoemission than plain Mo wire, and caused accelerated sodium loss and hence reduced life.  It was necessary to go back to pure Mo wire again.
