Author Topic: Does Transporting BT-shaped Mercury Lamps Cause Looseness?  (Read 5146 times)
Maxim
Does Transporting BT-shaped Mercury Lamps Cause Looseness? « on: January 22, 2026, 11:24:35 PM » Author: Maxim
So a slightly odd question but, do "full-frame" lamps loosen over time from vibrations in a car? Ie, the lamp is in a sleeve, in a cardboard box, alongside another, similar lamp. So no room to roll around, but just enough room to not take the shock to its internals... or so I thought.
Does driving with lamps, especially those that are BT-shaped, affect arc tube frame sturdiness, ie, does the lamp "rattle" more after spending time in such conditions? And even though such conditions are present, do potholes wreak havoc on sensitive internal parts????
For a bit of context here, I took three vintage lamps out with me this weekend (1/18). They were stacked neatly in a cardboard box (with a fourth, sealed-in-box LED retrofit lamp in a perfect spot to allow for stability) for an interview for one of my colleges. Well, I forgot about them until this evening, and when I took them out of the car, I swore their rattling noises were more pronounced. However, I do not have a definite recollection of how loud or quiet they were prior to spending four days in the trunk of my car.
Thoughts??? Did I "ruin" a couple of perfectly-good lamps internally??
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #1 on: January 23, 2026, 03:08:43 AM » Author: Medved
Shaking them around definitely won't help, so if you kept them in the car boot for unnecessarily long time just because you were too busy to take them out, I would say you did cause some damage. It even may not be the rattling itself, but e.g. some cracks propagating further, so leaving less margin till a failure.
Maxim
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #2 on: January 27, 2026, 08:28:26 PM » Author: Maxim
Good to know, thank you.
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #3 on: February 06, 2026, 06:53:08 AM » Author: James
Normally not.  The support frames are usually made of nickel with 2-3% manganese addition, to pin the nickel grain boundaries.  This gives the material surprisingly good elasticity.  Of course if you apply sufficient force to take the metal beyond its yield point then a permanent deformation could happen.  Also in case of shocks while hot thar can happen more easily.  But I would not be too concerned about transport by car.
What could happen is that the quartz arc tube becomes a bit looser in its metal clamps to the frame.  The quartz pinches are often a bit irregular in shape, and the metal straps do not always clamp them at their widest points.  Small movements may cause the arc tube to slip between its supports, and if it is thinner at that point it may then rattle more.
Maxim
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #4 on: February 06, 2026, 08:59:50 AM » Author: Maxim
@James — I see. I believe that is what happened with two of my lamps; they somewhat "slipped" out of place, making their rattling more pronounced. But no permanent deformation.
Is there any way to make the frame "slip" its way back in place? Thanks for your reply!
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #5 on: February 09, 2026, 01:40:11 AM » Author: James
Usually the shift is in the axial direction, so with some judicious tapping from the base or dome end you might succeed to move it slightly back in place.  But it is in practice difficult to make thibgs tighter.  It is equally likely that you make it even looser.
I would not worry about it.  If they are older lamps they will have been rigorously vibration-tested during development and can more than stand the slight loosening of clamp points, it’s not detrimental in any way.  And it lets you learn another characteristic of different lamp brands - how they sound!
Some colleagues at GE who handled the different HID lamps every day used to swear that they could identify any competitor brand lamp with their eyes shut, just from the unique pinging noises that they made while being handled or due to thermal expansion when running up!  Almost anyone in the UK who has handled a GEC lamp will know what I mean, those had much stiffer frame alloys of nickel plated steel and quite loose top dimple supports, and produced a totally different sound than any other brand.
« Last Edit: February 09, 2026, 01:44:42 AM by James » Logged
Maxim
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #6 on: February 09, 2026, 05:08:26 PM » Author: Maxim
@James — thanks for the explanation. Actually, something pretty funny happened. Was walking up the stairs with one of these lamps (Westinghouse H39KB-175) and the lamp, plus its sleeve, rolled down carpeted stairs in what I could only describe in slow motion. Well, lo and behold, it no longer rattles! Not a sound when I whack it from any side.
Though, I would say the arc tube is now about 1-2° off center in the vertical axis, though I guess that's the price I paid for no rattling. :lol:
And also interesting that GE engineers claimed that they could identify which company made what lamp based on sound alone. Which is also interesting because very few, if any, of my USA-made GE lamps rattle or vibrate. Made in Hungary/China, however? Different story.
Also, those GE engineers must've sat in a circle one day and laughed hysterically at the failure that was Philips' transition to ED-shaped lamps! Because every single one that I have rattles to no end, and loudly at that.  ;D
Multisubject
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #7 on: February 09, 2026, 05:30:47 PM » Author: Multisubject
Holy crud! My heart would be absolutely POUNDING if that happened to me lol! Thank goodness the lamp is okay, and very interesting that the rattle stopped.
I guess percussive maintenance is the key to rattle elimination...
Maxim
Re: Does Transporting BT-shaped Mercury Lamps Cause Looseness? « Reply #8 on: February 09, 2026, 11:55:41 PM » Author: Maxim
Yeah. I'm simply lucky the lamp was in its tight-fitting sleeve!
