Author Topic: Hall of shame - show your *worst* lamps and fixtures  (Read 5347 times)
Laurens
Hall of shame - show your *worst* lamps and fixtures « on: January 26, 2026, 02:07:40 PM » Author: Laurens
Last time i was at the thrift shop, i grabbed a Calex GU10 CFL spotlight and it is just hilariously bad.
Why? You're looking at the tops of the U-bends of the discharge tube. The 'reflector' is cylindrical so most light just gets bounced around the cylinder. It runs extremely hot, you cannot touch the thing after it's been running for 15 minutes. The internal reflector is a piece of aluminium so almost all heat emitted by the discharge tube just gets sent right back into itself. The rest of the housing is plastic.
It draws 9w of power and puts out a claimed 190lm, so the efficiency is essentially on par with some of the better halogen spotlights. Yet it claims to offer 80% energy savings.
So what are your worst ones, that you keep around just because they're so awful?
Another one worth a mention here is a self ballasted blacklight MV lamp. I'll dig that one up later and post it. Very sloppy construction, mediocre output.
« Last Edit: January 26, 2026, 02:12:06 PM by Laurens » Logged
Multisubject
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #1 on: January 26, 2026, 03:01:03 PM » Author: Multisubject
Wow, that is an efficiency nightmare.
My pick is probably my purple Diazotype reprographic 400W MH lamp (my profile picture). Don't get me wrong, it does look cool when lit, that is why I chose it as my profile picture. But there are a few reasons I am not exactly a fan of it:
- First HID lamp I ever got, looks 100% normal, was expecting it to be normal/usable
- Light output is not usable, may or may not contain harmful UV (nobody seems to know)
- Cycles on it's appropriate ballast (even though arc tube looks pretty new), can only be run up nicely with added CWA capacitance
- BT-37 takes up a lot of my space, and I don't ever even take it out of the box anymore
- Even if it did work right and wasn't harmful, the hour rating of these kinds of lamps is apparently crud anyway
Honestly if I could magically wake up and have this lamp transformed into a normal 400W MH, that would be great. It is just a waste of my space. But I am not gonna just throw it away because they aren't super common, maybe some day someone will give it a loving home lol.
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #2 on: January 26, 2026, 03:04:32 PM » Author: LightsAreBright27
1. Suralux 10w tube and 15w tube. On the 10w tube they forgot to dip the electrodes in emission coating, so it doesn't start on electronic. On the 15w tube, they made it the wrong size (F14T8 instead of F15T8) and they got the phosphor color to be 5000k though it's labelled 6500k.
2. Madhab neon flicker flame lamp. I have no issue with the glass part of the lamp, it's the base. Its made of cheap bright flashy plastic, and the B22 pins are plastic too. The B22 contacts are just screws. It just looks too hideous. A metal B22 base with ceramic filling would look 10 times better.
3. Philips 15w blue glazed incandescent. Blue glaze is a very dim color, not suitable for a low wattage like 15w. Hence, the lamp is half as bright as a small led, and consumes 15w. The other 15w incandescents like green, yellow and red are brighter than the blue one. I don't understand why they didn't use translucent blue lacquer instead of blue glaze.
4. Mysore 160w SBMV. They used the design from philips, who made a flawed design. They placed the starting electrode too close to the main electrode, which meant mercury would short the electrodes resulting in the lamp shutting off after 10 secs. The lamp had to be run at a 45
angle to even function.
These are just non-LED lamps. I have had many brand new led lamps just burn out minutes after they were turned on. Like this led bulb and this led strip.
Worst fixture I made is putting 6x 18w led spotlights of different colors in a 250w HID fixture. The hideous fixture is here.
There was also an idol frame that had leds on it, but it's power supply was horrendous and dangerous.
« Last Edit: January 26, 2026, 03:28:04 PM by LightsAreBright27 » Logged
245v 50Hz
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #3 on: January 26, 2026, 04:05:45 PM » Author: Ash
It is hard to beat the cheapest LED lamps from Ebay of the mid 2010s off the top of the list....
I had a friend who was all into buying that sort of stuff just for entertainment. (Had, he was an old guy and not too healthy, and passed away since)
When the lamps died (with the series string of LEDs going open circuit, which leads to electrolytic cap charging to full line voltage, going past its voltage rating and blowing up with smoke), we would get out the soldering iron and blob some solder over the dead LED to keep the lamp going for another couple days. (Soldering iron also straight from China, ungrounded plug, makes the LEDs on the PCB light up as you are soldering them. Sitting in Lotus position in the plastic chair helped reduce risk of electric shock)
Excluding them, it is still hard to beat many other LED lamps off the top of the list. I'll summarize this with a quote from a salesperson of Z&S, an importer of cheap lamps. (Context : Was his answer when i asked why a LED panel light they sell does not have a lifetime hour rating on the box, but only some ridiculous number in years with small print)
"Our LED lamps are the highest quality, such that their lifetime is measured in years and not in hours"
Of non LED lamps, i'd say most 4-6-8W T5's sold in stores nowadays, and a few 15W and 18W T8's
They have virtually no emitter on one or both cathodes. They appear to be either slightly rectifying, or even "rectifying" on both electrodes (ie. formally not rectifying, but running with abnormal crest factor) from the first start. They may start flashing like EOL randomly while running. They are flashing a lot when starting
Connecting such lamp with a shorted starter reveals that the electrode filaments may be different from each other or even shorted - One lights, one doesn't or they are of different brightness by a few times
Of older lamps, it's a tie between...
CFLs of the early 00's which keep burning up the circuit (scorching hot, no light, no cathode glow) many days or weeks after they EOL'd. Ballast case plastic crushes to dust in hand when trying to remove the lamp from the socket
Festoon incandescent lamps which paint coat goes up in smoke after the lamp heats up (not EOL)
Incandescent lamps with the wires in the cap twisted (short circuit) from the factory
Incandescent lamps which cement is loose from the factory (during screwing the lamp into the socket)
Circlines that work normally once, have no vacuum (or poisoned ?) when switched on 2nd time next day. Replace with new one and same thing happens again
Starters stuck new from the factory
Starters which bimetal presses the glow lamp wall from inside and pops it open after a few uses
Starters which bimetal is broken and just lays loose inside the lamp. Those catch fire when put into use
SON-T lamp with E40 base which doesn't go into most E40 sockets (it's not E39 either, it's something incorrectly shaped not compatible with any of them)
Maxim
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #4 on: January 28, 2026, 08:32:52 AM » Author: Maxim
@Multisubject — do you want a NORMAL MH400?
My biggest peeve is bad lighting. Ie, half-assed, poorly-maintained lighting installs. I have somewhat of a "perfectionist" nature, so if something like a chandelier has 16 different kinds of bulbs and three color temperatures, I will not be able to focus on anything else in the room, no matter how "nice" it may be.
Also flickering LEDs are up there. Recent-manufacture lamps from the likes of K-Lite (branded Philips) have a tendency to flicker horribly for no particular reason. They are straight junk in every application, and not worth more than $1/lamp, "unique" attributes aside (ie, SceneSwitch).
I also can't stand missouts. Like you went out of your way to replace every light in town. So WHY is there a light smack in the middle of it all, that is probably EOL, that is still in place??? My only exception to this rule is when a light left lit is something like a vintage MV lamp (ie, a local town converted entirely to LED, and they missed a Westinghouse OV-15 that's been reliably lighting dusk to dawn for the past 25 or so years).
There are more, but that's all I can think of so far.
« Last Edit: January 28, 2026, 08:40:25 AM by Maxim » Logged
Multisubject
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #5 on: January 28, 2026, 09:14:49 AM » Author: Multisubject
Not enough to go through the effort of actually buying one, but kinda lol. I just want this piece of crud out of my vicinity.
Maxim
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #6 on: January 28, 2026, 09:41:36 AM » Author: Maxim
@Multisubject — if we ever meet up, I can give you one or multiple. I have more than enough.
Multisubject
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #7 on: January 28, 2026, 10:12:38 AM » Author: Multisubject
Sooooold!!! I don't have the lamp in my dorm right now but I will figure it out if you ever find yourself near here
rapidstart_12
@rs12official
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #8 on: January 29, 2026, 08:10:16 PM » Author: rapidstart_12
I agree and I certainly can’t stand it when residential/decorative fixtures have different colors or styles of bulbs in them. However, for fluorescent in particular, there is a bit of a nostalgic element to having different colors of bulbs because I remember when businesses near where I live had such installations back before I started to see LED more often, in fact some still do. So I do sometimes like mixed color fluorescent installations, especially if there is a mix of eras of bulbs too.
Maxim
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #9 on: January 30, 2026, 12:05:09 AM » Author: Maxim
@rapidstart_12 — same here. I have a twin-PL bulkhead in the backyard with one Charlestown, UK-made Sylvania PL-13 (GTE) in 2700K, as well as a Bari, Italy-made PL-9 (Osram) in 4000K. I love their differing startups / final warm up colors. Very much a nostalgic sight indeed.
Re: Hall of shame - show your *worst* lamps and fixtures « Reply #10 on: February 01, 2026, 04:49:12 PM » Author: wide-lite 1000
 I've seen missouts here which were caused by blocked access to said fixture during the changeout process .
