Author Topic: Neon-Filled CRT with Visible Electron Beam!  (Read 8862 times)
Multisubject
Neon-Filled CRT with Visible Electron Beam! « on: February 16, 2026, 12:49:42 PM » Author: Multisubject
Very cool to see, I didn't think a CRT could even work with that much gas inside it. You can see the red glowing electron beam emerging from the very primitive electron gun, and it seems to visibly reach it's focal point before it reaches the phosphor screen (unsurprising as it has no focus electrode).
https://www.youtube.com/watch?v=mOAEv-jZarM
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #1 on: February 16, 2026, 12:56:56 PM » Author: LightsAreBright27
Very cool indeed! Imagine if someone put deflection coils, and did some slow scan vector images. That neon beam moving around would bw so cool.
245v 50Hz
Multisubject
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #2 on: February 16, 2026, 01:10:07 PM » Author: Multisubject
@LightsAreBright27
Omg yes! The effect would be enhanced with some longer persistence phosphor (and a focusing setup with either a coil permanent magnets), but yes that would look very very cool
lightsofpahrump
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #3 on: February 20, 2026, 10:51:02 PM » Author: lightsofpahrump
I would like to see that displaying not only vector, but raster graphics. The glow filling the tube would look cool.
I like math, lighting, computers and electronics(but I detest pointless ruinage of nice old stuff). LEDs should be better thought out. they are actually quite good if they are good quality. They should be built to a long life not to a cheap price!
Freedom's not slavery, communism is!
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #4 on: February 21, 2026, 03:41:17 AM » Author: LightsAreBright27
@lightsofpahrump raster would be cool, but it doesn't work well on slow scan CRTs. If you want to make the scanning rate faster, the neon beam would be moving too quick so it will become too faint to see
245v 50Hz
lightsofpahrump
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #5 on: February 27, 2026, 07:34:01 PM » Author: lightsofpahrump
Then how about running a low resolution like the 30 lines of Baird's mechanical televisor? That could scan slowly enough to have the beam be seen, remember that 30 non-interlaced was chosen as a compromise between detail and flicker on the rather slow mechanical system/
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #6 on: February 28, 2026, 04:30:39 AM » Author: RRK
One can coat the screen with modern long-persistent strontium aluminate phosphor. It is vacuum compatible. I bet educational effect will be even better with phosphorescent image gradually disappearing and refreshing with slow scan!
Laurens
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #7 on: February 28, 2026, 04:43:22 AM » Author: Laurens
Think about it this way: The faint light of the electron beam through the gas is already faint as a single beam.
Now you are going to spread the same amount of light energy over a larger area as you pass the deflection coils. The same amount of photons divided by a larger area, makes the brightness incredibly low.
If you increase the beam current, you'll be able to see it. That might actually be necessary to make the image on screen bright enough, because the dot of light will also be spread over a larger area. If you adjust the dot of light on an XY scope with no signal to normal brightness and then apply signal, the trace will be very faint.
lightsofpahrump
Re: Neon-Filled CRT with Visible Electron Beam! « Reply #8 on: September 16, 2026, 05:47:21 PM » Author: lightsofpahrump
Also, maybe this monstrosity actually needs more beam current or voltage to get normal screen brightness because of the neon.Would be cool to see one with mercury vapor inside if indeed that was doable!
